Help
page!
Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12207
questions
Tagged
13
views
answer
no
votes
2024-05-07 02:27:04 -0500
Tokarzewski
"Failed to process line" when trying to open .ESO file DesignBuilder
designbuilder
designbuilder-results-viewer
error
eso-file
134
views
answer
no
votes
2024-05-07 02:07:56 -0500
station12
Simulation Error (OpenStudio)
buildings
construction
errors
openstudio
view
no
answers
no
votes
2024-05-07 01:45:59 -0500
Mike117
How should I fix the UpdateZoneSizing message? Why does one error produce a warning and the other a severe warning?
troubleshooting
hvac-sizing
zone-sizing
openstudio
energyplus
14
views
no
answers
no
votes
2024-05-06 17:25:26 -0500
Mike117
How do I model a tempered air damper and heat exchanger without a dedicated outdoor air system in Openstudio/EnergyPlus?
hvac-control
airloop
openstudio
energyplus
51
views
answer
no
votes
2024-05-06 15:23:52 -0500
Craig Simmons
Why is my During Heating unmet hours measurement much higher than my During Occupied Heating unmet measurement?
output-report
unmet-hours
openstudio-application
supply-temperature
energyplus
9
views
no
answers
no
votes
2024-05-06 11:52:57 -0500
Udara Sachinthana
energyplus
outputs
ventilation
summary-report
fan
53
views
answers
vote
2024-05-06 10:28:31 -0500
shorowit
openstudio
energyplus
urbanopt
output-meter
25
views
no
answers
no
votes
2024-05-06 09:40:17 -0500
Aaron Boranian
Calculation point problem for Radiance Measures
radiance
openstudio-measure
daylighting-metric
daylighting
15
views
answer
votes
2024-05-06 09:29:53 -0500
shorowit
Inconsistent results modelling Net-Zero homes in BEopt 2.8
beopt
net-zero
energy-rating-index
52
views
answer
votes
2024-05-06 09:15:33 -0500
PmP
epw
indoor-temperature
outdoor-temperature
internal-mass
energyplus
52
views
answer
no
votes
2024-05-05 20:52:19 -0500
Keigo
energyplus
openstudio
airloophvac
make-up-air-unit
outdoor-air
25
views
no
answers
no
votes
2024-05-04 15:59:32 -0500
Joe Huang
Are there any plans to update the EnergyPlus Weather Converter program to use more current ASHRAE Design Conditions? [closed]
energyplus-weather-converter
23
views
no
answers
votes
2024-05-04 15:54:00 -0500
Joe Huang
EnergyPlus Weather program still uses ASHRAE 2013 design conditions. Are there any plans to update that to current ASHRAE 2021 weather conditions?
design-day
epw-file
ashrae
7
views
no
answers
vote
2024-05-04 11:03:45 -0500
alfred.levison
VRF system Fan:system model energy calculation
vrf
energyplus
fan
67
views
no
answers
votes
2024-05-03 02:59:48 -0500
the_donn
openstudio
installation
error
openstudio-sdk
ladybug
56
views
answer
vote
2024-05-01 22:34:25 -0500
Mike117
measures
energyplus-measure
output-diagnostics
error
37
views
no
answers
vote
2024-05-01 12:29:39 -0500
Greg Estep
mixed water loop flow issues
designbuilder
geothermal
dual-setpoint
energyplus
hvac-control
29
views
no
answers
no
votes
2024-04-30 12:45:39 -0500
BalKrishna
ground-source-heat-pump
fluid-cooler
energyplus
condenser-loop
hvac-control
68
views
answer
votes
2024-04-30 09:44:53 -0500
Zakaria
energyplus
construction
surfaces
boundary-condition
airflow-network
53
views
no
answers
no
votes
2024-04-30 09:01:17 -0500
Irfan
energyplus-api
output-meter
energyplus
ep-launch
57
views
answer
4
votes
2024-04-29 23:53:47 -0500
cmui
openstudio
openstudio-hpxml
energyplus
simulation-time
openstudio-measure
17
views
no
answers
no
votes
2024-04-29 21:07:10 -0500
Arex
beopt
29
views
no
answers
no
votes
2024-04-29 13:57:04 -0500
MapMortar
openstudio-sdk
district-cooling
sql-file
ideal-loads-air-system
peak-demand
25
views
no
answers
no
votes
2024-04-29 06:37:38 -0500
CoolAlfo
ladybug
grasshopper
energyplus
output-variable
61
views
no
answers
no
votes
2024-04-28 23:10:35 -0500
Mike117
openstudio-results
energyplus
thermal-comfort
ashrae-55
summary-report
55
views
no
answers
vote
2024-04-28 18:18:31 -0500
Ehsank
energyplus
hpc
beopt
computer-hardware
compute-cluster
59
views
no
answers
no
votes
2024-04-28 15:24:57 -0500
Mike117
Why do I get error messages when I add measures?
openstudio
reporting-measure
error
openstudio-sdk
78
views
answer
vote
2024-04-27 12:46:43 -0500
macumber
Adjusting the building square footage of an existing osm in SketchUp
sketchup-openstudio-plugin
openstudio
geometry
39
views
no
answers
no
votes
2024-04-26 18:14:52 -0500
James_BC
Another Error Using create_typical_building_from_model
comstock
openstudio-sdk
openstudio-standards
error
openstudio
14
views
no
answers
no
votes
2024-04-25 21:28:45 -0500
xchen
sizing
energyplus
design-day
heating-coil
doas
5
407
next page »
Careers
Contributors
Tags
energyplus
×17
openstudio
×10
error
×5
openstudio-sdk
×4
beopt
×3
hvac-control
×3
construction
×2
designbuilder
×2
design-day
×2
×2
fan
×2
ladybug
×2
openstudio-measure
×2
output-meter
×2
summary-report
×2
airflow-network
×1
airloop
×1
airloophvac
×1
ashrae
×1
ashrae-55
×1
boundary-condition
×1
buildings
×1
compute-cluster
×1
computer-hardware
×1
comstock
×1
condenser-loop
×1
daylighting
×1
daylighting-metric
×1
×1
district-cooling
×1
doas
×1
dual-setpoint
×1
energyplus-api
×1
energyplus-measure
×1
energy-rating-index
×1
ep-launch
×1
epw
×1
epw-file
×1
errors
×1
eso-file
×1
fluid-cooler
×1
geometry
×1
geothermal
×1
grasshopper
×1
×1
heating-coil
×1
hpc
×1
hvac-sizing
×1
×1
indoor-temperature
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
