Help
page!
Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12243
questions
Tagged
69
views
answer
no
votes
2024-05-20 09:07:01 -0500
Aaron Boranian
energyplus
openstudio-application
designbuilder-results-viewer
eso-file
17
views
answer
no
votes
2024-05-19 16:07:03 -0500
efrainpuerto
openstudio
ubuntu
installation
compatibility
10
views
no
answers
no
votes
2024-05-19 11:10:47 -0500
LucasL
OpenStudio Application on Ubuntu 24.04 [closed]
openstudio
ubuntu
installation
compatibility
66
views
answers
no
votes
2024-05-17 13:10:57 -0500
JasonGlazer
hvac
infiltration
outdoor-air
energyplus
8
views
no
answers
no
votes
2024-05-17 10:18:20 -0500
Burns
pyfmi
error
delta
energyplus
fmu
13
views
no
answers
no
votes
2024-05-17 08:53:48 -0500
DSMEAEP
district-heating
heating-load
ideal-loads-air-system
15
views
no
answers
no
votes
2024-05-17 08:40:02 -0500
Aaron Boranian
hvac
error
hvac-template
energyplus
15
views
no
answers
no
votes
2024-05-17 07:49:27 -0500
Burns
[Jupyter] AttributeError: module 'PyFMI' has no attribute 'load_fmu'
conda
pyfmi
import
python
jupyter
40
views
answer
no
votes
2024-05-17 07:28:59 -0500
Burns
energyplus
fmu
energyplus-to-fmu
severe-error
cooling
15
views
no
answers
no
votes
2024-05-17 06:38:47 -0500
RichardT
iecc
cooling-capacity
heating
heating-capacity
reference
140
views
answer
vote
2024-05-16 13:01:01 -0500
efrainpuerto
ems
energyplus
severe-error
node-connection
ems-control
1k
views
answer
no
votes
2024-05-16 12:38:25 -0500
MJWitte
Error when using PTHP
error
pthp
166
views
answer
vote
2024-05-16 12:34:56 -0500
MJWitte
hvac-template
fan
pthp
energyplus
fatal
60
views
no
answers
no
votes
2024-05-16 10:40:56 -0500
Burns
error
energyplus
fmpy
fmu
exception
32
views
no
answers
no
votes
2024-05-16 07:54:14 -0500
chloe
trnsys
vrf
40
views
no
answers
no
votes
2024-05-16 06:11:04 -0500
chloe
vrf
openstudio
energyplus
hvac-control
67
views
answer
vote
2024-05-16 05:27:22 -0500
Denis Bourgeois
asset-score
apply-measure
openstudio
openstudio-sdk
31
views
answer
no
votes
2024-05-16 04:19:08 -0500
Craig Simmons
openstudio
energyplus
error
81
views
no
answers
no
votes
2024-05-15 11:59:17 -0500
chloe
plz... help me. how to do openstudio.
openstudio
vrf
energyplus
hvac
105
views
answer
vote
2024-05-15 11:58:11 -0500
Aaron Boranian
fmpy
energyplus
fmu
error
energyplus-to-fmu
29
views
answer
no
votes
2024-05-15 09:39:15 -0500
Craig Simmons
Seeking Advice on HVAC System Template for Mid-Rise Apartment Project
split-system
hvac
38
views
answer
4
votes
2024-05-15 07:32:35 -0500
Burns
idf
energyplus
geometry
eppy
coordinates
18
views
no
answers
vote
2024-05-15 03:59:23 -0500
Alberta Carella
OpenStudio Application support and training
training
89
views
no
answers
vote
2024-05-15 02:39:45 -0500
Roy_Xu
energyplus
daylighting-control
ems
dgi
shading-control
32
views
no
answers
no
votes
2024-05-14 21:37:56 -0500
Marcos Braz
Energy Plus Two water heaters with two source sides in the same loop.
energyplus
hot-water-loop
air-to-water-heat-pump
solar-collector
plant-loop
50
views
answer
votes
2024-05-14 18:15:40 -0500
shorowit
hvac-control
openstudio
vrf
heating-coil
schedule
66
views
no
answers
no
votes
2024-05-14 12:43:32 -0500
sz1980
Python API: Actuators all zero
ems
python-ems
energyplus
python-plugin
ems-control
73
views
answer
no
votes
2024-05-14 07:54:19 -0500
Denis Bourgeois
What is the solution to the SWIG error in this simulation run? I tried adding two measures Add Meter and ExportMetertoCSV.
measures
energyplus
simulation-failure
openstudio
reporting-measure
200
views
no
answers
vote
2024-05-13 14:20:19 -0500
sduncan
openstudio-pat
parametric-analysis-tool
ms-windows
error
396
views
no
answers
vote
2024-05-13 09:33:47 -0500
adrisnnt
DesignBuilder IDF Import problems
designbuilder
idf
energyplus
coordinates
import
5
409
next page »
Careers
Contributors
Tags
energyplus
×18
×10
openstudio
×8
error
×7
fmu
×4
hvac
×4
vrf
×4
ems
×3
compatibility
×2
coordinates
×2
ems-control
×2
energyplus-to-fmu
×2
fmpy
×2
hvac-control
×2
hvac-template
×2
×2
idf
×2
import
×2
installation
×2
pthp
×2
pyfmi
×2
severe-error
×2
ubuntu
×2
×1
apply-measure
×1
asset-score
×1
conda
×1
cooling
×1
cooling-capacity
×1
daylighting-control
×1
delta
×1
designbuilder
×1
×1
dgi
×1
district-heating
×1
eppy
×1
eso-file
×1
exception
×1
fan
×1
fatal
×1
geometry
×1
heating
×1
heating-capacity
×1
heating-coil
×1
heating-load
×1
hot-water-loop
×1
iecc
×1
infiltration
×1
jupyter
×1
measures
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
