Help
page!
Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12732
questions
Tagged
24
views
answer
no
votes
42 mins ago
Greg Estep
Correct settings for setback temperature in DesignBuilder
designbuilder
availability-schedule
detailed-hvac
occupancy
thermostat
31
views
answer
vote
2 hours ago
mther
Time not Meeting Adaptive Comfort Percentage
temperature
adaptive-comfort
openstudio
thermal-comfort
occupancy
69
views
answer
no
votes
16 hours ago
Denis Bourgeois
Solar Distribution: FullExterior vs FullInteriorAndExteriorWithReflection on skylight.
skylight
energyplus
severe-error
geometry
solar-distribution
8
views
no
answers
vote
21 hours ago
Aaron Boranian
Issue with EMS Construction State Actuator and Finite Difference Nodes
ems
actuator
pcm
energyplus
condfd
31
views
answer
no
votes
41 hours ago
BrianLBall
Unable to start PAT Server 3.9.0
pat
server
startup
error
openstudio-pat
22
views
answer
no
votes
41 hours ago
BrianLBall
PAT datapoint failure
pat
datapoint
failure
errors
openstudio-pat
18
views
no
answers
no
votes
44 hours ago
LVT
Iterative daylighting calculations EnergyPlus
daylighting
energyplus
python-plugin
co-simulation
29
views
no
answers
no
votes
45 hours ago
jmoody
Create Typical Building From Model
measure
openstudio
openstudio-standards
error
climate
36
views
answer
vote
Feb 21
Denis Bourgeois
OpenStudio Sketchup plugin Root Directory for Mac
openstudio
openstudio-sketchup-plugin
mac-os
100
views
no
answers
vote
Feb 21
ShiweiNG
Horizontal surface selection and Evaporative Rate overwrite in IndoorLivingWall
ems
actuator
evapotranspiration
energyplus
greenhouse
33
views
answer
no
votes
Feb 21
mattkoch
Air Source Heat Pump for Heating Hot Water
air
air-source-heat-pump
boiler
heat-pump-water-heater
openstudio
17
views
no
answers
no
votes
Feb 20
Yun
EnergyPlus Cooling Tower Not Following Scheduled Shutdown
energyplus
cooling-tower
plant-equipment-operation
availability-manager
hvac-control
176
views
no
answers
no
votes
Feb 19
angelson
How to resolve gross_rated_sensible_heat_ratio error of EnergyPlus measures in OpenStudio
energyplus
energyplus-measure
openstudio
severe-error
dx-coil
33
views
answer
no
votes
Feb 19
angelson
How to resolve 1 Spd DX Clg Coil 7 is not aircooled or condenser type is aircooled?
openstudio
energyplusmeasures
condensertype
aircooled
13
views
no
answers
no
votes
Feb 19
RobinCris
output other equipment per flat per sub-category
output-meter
output-variable
energy-loads
ceiling-fan
energyplus
7
views
no
answers
no
votes
Feb 19
RobinCris
OtherEquipment output energy [closed]
equipment
output-meter
output-variable
ceiling-fan
energyplus
41
views
answers
no
votes
Feb 19
yiyuan-jia
VRF coils in VAV air terminal
vrf
vav
terminal-unit
energyplus
designbuilder
98
views
answers
votes
Feb 19
Dolf Bakker
indoorlivingwall - LED Schedule produces constant output
energyplus
bug-report
lighting
output-variable
18
views
no
answers
no
votes
Feb 17
AadriaanW
Overhangs determined by angle instead of length
designbuilder
overhang
external-shading
parametric-analysis
25
views
no
answers
vote
Feb 17
Piyush
Automated eQuest runs are generating some (not all) truncated SIM files
equest
parametric
sim
python
batch-run
34
views
answer
votes
Feb 17
Keigo
Variable CHW Flow Chillers Operate unexpectedly
energyplus
bug-report
chiller
chilled-water-loop
75
views
no
answers
no
votes
Feb 14
ArchJan
Window scaling error - baseline case model
wwr
designbuilder
application-error
baseline
ashrae-90.1
160
views
answer
vote
Feb 13
angelson
Openstudio version compatible with NREL fault measure
openstudio
openstudio-measure
operational-fault
53
views
no
answers
no
votes
Feb 13
ArchJan
How to model a modulating DX heat pump heating/cooling coil with modulating hot gas reheat
cool-reheat
packaged-heat-pump
reheat
designbuilder
energyplus
138
views
no
answers
no
votes
Feb 13
Aaron Boranian
Create DOE Prototype Building using Openstudio-Standards
commercial-prototype-building
error
125
views
answer
no
votes
Feb 13
Denis Bourgeois
How does zone simplify a typical building plan from different plans for simulation in EnergyPlus?
zone
energyplus
thermal-zone
simulation-time
55
views
no
answers
no
votes
Feb 13
Gyooyoo
sketchup can't display full openstudio model
sketchup-openstudio-plugin
openstudio
85
views
answer
vote
Feb 12
Denis Bourgeois
How can I calculate solar gains within Perimeter zones?
perimeter
solar-gain
energyplus
127
views
answer
no
votes
Feb 12
Denis Bourgeois
Sub Surface not being drawn because "base surface has less than 3 points".
subsurface
surface-matching
openstudio
error
169
views
answer
vote
Feb 11
Brooke_Energy
Open Studio Crashes Every time I try and open thermal zones
openstudio
openstudio-application
thermal-zone
application-error
bug-report
5
425
next page »
Careers
Contributors
Tags
energyplus
×14
openstudio
×10
designbuilder
×5
error
×4
bug-report
×3
output-variable
×3
actuator
×2
application-error
×2
ceiling-fan
×2
ems
×2
occupancy
×2
openstudio-pat
×2
×2
×2
output-meter
×2
pat
×2
×2
severe-error
×2
thermal-zone
×2
adaptive-comfort
×1
air
×1
aircooled
×1
×1
ashrae-90.1
×1
×1
×1
baseline
×1
batch-run
×1
boiler
×1
chilled-water-loop
×1
chiller
×1
climate
×1
×1
condensertype
×1
condfd
×1
cooling-tower
×1
cool-reheat
×1
co-simulation
×1
daylighting
×1
detailed-hvac
×1
dx-coil
×1
energy-loads
×1
energyplus-measure
×1
energyplusmeasures
×1
equest
×1
equipment
×1
errors
×1
evapotranspiration
×1
external-shading
×1
geometry
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
