Help
page!
Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12200
questions
Tagged
4
views
no
answers
no
votes
2024-05-04 15:59:32 -0500
Joe Huang
Are there any plans to update the EnergyPlus Weather Converter program to use more current ASHRAE Design Conditions?
energyplus-weather-converter
view
no
answers
no
votes
2024-05-04 15:54:00 -0500
Joe Huang
EnergyPlus Weather program still uses ASHRAE 2013 design conditions. Are there any plans to update that to current ASHRAE 2021 weather conditions?
10
views
no
answers
no
votes
2024-05-03 19:18:37 -0500
Mike117
Why is my During Heating unmet hours measurement much higher than my During Occupied Heating unmet measurement?
output-report
unmet-hours
openstudio-application
supply-temperature
energyplus
31
views
no
answers
vote
2024-05-03 13:46:37 -0500
gspahr
epw
indoor-temperature
outdoor-temperature
internal-mass
energyplus
35
views
answers
vote
2024-05-03 11:49:38 -0500
jordibrunet
openstudio
energyplus
urbanopt
output-meter
8
views
no
answers
no
votes
2024-05-03 08:26:36 -0500
Yagnik
energyplus
openstudio
airloophvac
make-up-air-unit
outdoor-air
40
views
no
answers
votes
2024-05-03 02:59:48 -0500
the_donn
openstudio
installation
error
openstudio-sdk
ladybug
40
views
answer
vote
2024-05-01 22:34:25 -0500
Mike117
measures
energyplus-measure
output-diagnostics
error
33
views
no
answers
vote
2024-05-01 12:29:39 -0500
Greg Estep
mixed water loop flow issues
designbuilder
geothermal
dual-setpoint
energyplus
hvac-control
27
views
no
answers
no
votes
2024-04-30 12:45:39 -0500
BalKrishna
ground-source-heat-pump
fluid-cooler
energyplus
condenser-loop
hvac-control
67
views
answer
votes
2024-04-30 09:44:53 -0500
Zakaria
energyplus
construction
surfaces
boundary-condition
airflow-network
50
views
no
answers
no
votes
2024-04-30 09:01:17 -0500
Irfan
energyplus-api
output-meter
energyplus
ep-launch
57
views
answer
4
votes
2024-04-29 23:53:47 -0500
cmui
openstudio
openstudio-hpxml
energyplus
simulation-time
openstudio-measure
12
views
no
answers
no
votes
2024-04-29 21:07:10 -0500
Arex
beopt
25
views
no
answers
no
votes
2024-04-29 13:57:04 -0500
MapMortar
openstudio-sdk
district-cooling
sql-file
ideal-loads-air-system
peak-demand
23
views
no
answers
no
votes
2024-04-29 06:37:38 -0500
CoolAlfo
ladybug
grasshopper
energyplus
output-variable
56
views
no
answers
no
votes
2024-04-28 23:10:35 -0500
Mike117
openstudio-results
energyplus
thermal-comfort
ashrae-55
summary-report
20
views
no
answers
vote
2024-04-28 18:18:31 -0500
Ehsank
energyplus
hpc
beopt
computer-hardware
compute-cluster
27
views
no
answers
no
votes
2024-04-28 15:24:57 -0500
Mike117
Why do I get error messages when I add measures?
openstudio
reporting-measure
error
openstudio-sdk
68
views
answer
no
votes
2024-04-27 12:46:43 -0500
macumber
Adjusting the building square footage of an existing osm in SketchUp
sketchup-openstudio-plugin
openstudio
geometry
35
views
no
answers
no
votes
2024-04-26 18:14:52 -0500
James_BC
Another Error Using create_typical_building_from_model
comstock
openstudio-sdk
openstudio-standards
error
openstudio
14
views
no
answers
no
votes
2024-04-25 21:28:45 -0500
xchen
sizing
energyplus
design-day
heating-coil
doas
12
views
no
answers
no
votes
2024-04-25 15:38:35 -0500
Rezvan
Whole house fan in energyplus
fan
energyplus
residential
mechanical-ventilation
66
views
answer
vote
2024-04-25 11:53:41 -0500
James_BC
comstock
openstudio-sdk
4
views
no
answers
no
votes
2024-04-25 10:10:40 -0500
Bernard Kim
Having Trouble With Ideal Loads Air System [closed]
energyplus
ladybug
zone-sizing
design-day
30
views
no
answers
no
votes
2024-04-25 08:10:54 -0500
ag
How to model gravity ventilators in Design Builder
designbuilder
exhaust-fan
77
views
no
answers
vote
2024-04-25 01:18:58 -0500
Roy_Xu
energyplus
daylighting-control
ems
dgi
shading-control
28
views
no
answers
no
votes
2024-04-24 23:17:12 -0500
zoops
openstudio-results
error
openstudio
summary-report
89
views
answer
vote
2024-04-24 18:53:06 -0500
James_BC
openstudio-sdk
comstock
38
views
answer
vote
2024-04-24 15:58:50 -0500
andrefsl
external-shading
openstudio
floorspace.js
5
407
next page »
Careers
Contributors
Tags
energyplus
×16
openstudio
×9
openstudio-sdk
×6
error
×5
comstock
×3
ladybug
×3
×3
×3
beopt
×2
designbuilder
×2
design-day
×2
×2
hvac-control
×2
×2
×2
openstudio-results
×2
output-meter
×2
summary-report
×2
airflow-network
×1
airloophvac
×1
ashrae-55
×1
boundary-condition
×1
compute-cluster
×1
computer-hardware
×1
condenser-loop
×1
construction
×1
daylighting-control
×1
dgi
×1
district-cooling
×1
doas
×1
dual-setpoint
×1
ems
×1
energyplus-api
×1
energyplus-measure
×1
ep-launch
×1
epw
×1
exhaust-fan
×1
external-shading
×1
fan
×1
floorspace.js
×1
fluid-cooler
×1
geometry
×1
geothermal
×1
grasshopper
×1
×1
heating-coil
×1
hpc
×1
indoor-temperature
×1
installation
×1
internal-mass
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
