Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12227
questions
Tagged
18
views
no
answers
vote
2024-05-14 18:02:13 -0500
llisell
asset-score
apply-measure
openstudio
openstudio-sdk
43
views
no
answers
no
votes
2024-05-14 12:43:32 -0500
sz1980
Python API: Actuators all zero
ems
python-ems
energyplus
python-plugin
ems-control
27
views
answer
no
votes
2024-05-14 07:54:19 -0500
Denis Bourgeois
What is the solution to the SWIG error in this simulation run? I tried adding two measures Add Meter and ExportMetertoCSV.
measures
energyplus
simulation-failure
openstudio
reporting-measure
9
views
no
answers
votes
2024-05-14 03:00:21 -0500
Tokarzewski
idf
energyplus
geometry
eppy
coordinates
85
views
no
answers
vote
2024-05-13 21:15:17 -0500
Roy_Xu
energyplus
daylighting-control
ems
dgi
shading-control
116
views
no
answers
vote
2024-05-13 14:20:19 -0500
sduncan
openstudio-pat
parametric-analysis-tool
ms-windows
error
41
views
no
answers
vote
2024-05-13 09:33:47 -0500
adrisnnt
DesignBuilder IDF Import problems
designbuilder
idf
energyplus
coordinates
import
87
views
answer
votes
2024-05-13 08:29:17 -0500
Zakaria
energyplus
construction
surfaces
boundary-condition
airflow-network
25
views
no
answers
no
votes
2024-05-12 22:32:32 -0500
YuqngYang
Ice Rink Modeling
ice-rink
energyplus
equest
16
views
answer
no
votes
2024-05-12 15:07:02 -0500
Greg Estep
Design Builder Heating Coil Nominal Capacity
designbuilder
energyplus
heating-coil
heating-capacity
86
views
answer
vote
2024-05-12 09:25:25 -0500
Aaron Boranian
Basic low temperature electric radiant heating
low-temperature-radiant
energyplus
10
views
no
answers
no
votes
2024-05-12 03:46:56 -0500
gulce
Seeking Advice on HVAC System Template for Mid-Rise Apartment Project
split-system
hvac
openstudio-application
220
views
answer
vote
2024-05-10 19:14:17 -0500
SJ LEE
Nothing in online BCL
bcl
openstudio
measure
52
views
no
answers
no
votes
2024-05-10 16:49:11 -0500
natalie_low
Tips or work arounds for running BuildStockQuery when encountering UnrecognizedClientException?
nrel
resstock
buildstock-query
oedi-data-lake
107
views
answer
votes
2024-05-10 12:11:25 -0500
gspahr
epw
indoor-temperature
outdoor-temperature
internal-mass
energyplus
31
views
no
answers
no
votes
2024-05-10 09:53:51 -0500
ajith
hvac-control
openstudio
vrf
heating-coil
schedule
87
views
answer
no
votes
2024-05-10 08:38:19 -0500
Yi Zhang
TRNSYS and JEPlus
trnsys
jeplus
parametric-analysis
50
views
no
answers
no
votes
2024-05-09 15:05:10 -0500
DSMEAEP
Where did my JS floorplan go [closed]
floorspace.js
251
views
answer
no
votes
2024-05-08 23:10:03 -0500
station12
Interzone Surfaces : Constructions Search Distance and Mismatch Error (OpenStudio)
buildings
construction
errors
openstudio
96
views
no
answers
vote
2024-05-08 19:16:23 -0500
Aaron Boranian
Error in UserDefined HVAC Objects assembled
ems
energyplus
severe-error
node-connection
ems-control
4k
views
answer
vote
2024-05-08 18:41:09 -0500
efrainpuerto
ASHRAE 55 Adaptive Model doesn't report status in OpenStudio [closed]
adaptive
ashrae-55
openstudio
output-variable
134
views
answers
vote
2024-05-08 14:54:17 -0500
jordibrunet
openstudio
energyplus
urbanopt
output-meter
90
views
answer
vote
2024-05-08 04:57:48 -0500
TomB
How to add AFN in openstudio sdk
openstudio
airflow-network
afn
openstudio-sdk
18
views
no
answers
no
votes
2024-05-07 16:15:00 -0500
sheida
Negative Coordination
openstudio
energyplus
idf
geometry
coordinates
22
views
no
answers
no
votes
2024-05-07 10:49:32 -0500
hbh
Why is the internal shading effect better than the external shading?
shading-control
32
views
answer
vote
2024-05-07 08:39:09 -0500
JasonGlazer
energyplus
outputs
ventilation
summary-report
fan
29
views
answer
vote
2024-05-07 08:04:34 -0500
rraustad
How should I fix the UpdateZoneSizing message? Why does one error produce a warning and the other a severe warning?
troubleshooting
hvac-sizing
zone-sizing
openstudio
energyplus
20
views
answer
no
votes
2024-05-07 04:28:17 -0500
Alberta Carella
AWHP and booster for DHW with Setpoint Control
air-to-water-heat-pump
dhw
hvac-control
71
views
answer
no
votes
2024-05-07 04:01:35 -0500
PmP
energyplus-api
output-meter
energyplus
ep-launch
57
views
answer
no
votes
2024-05-07 02:27:04 -0500
Tokarzewski
"Failed to process line" when trying to open .ESO file DesignBuilder
designbuilder
designbuilder-results-viewer
error
eso-file
5
408
next page »
Careers
Contributors
Tags
energyplus
×16
openstudio
×10
×5
coordinates
×3
designbuilder
×3
ems
×3
idf
×3
airflow-network
×2
construction
×2
ems-control
×2
error
×2
geometry
×2
heating-coil
×2
hvac-control
×2
openstudio-sdk
×2
output-meter
×2
shading-control
×2
adaptive
×1
afn
×1
×1
apply-measure
×1
ashrae-55
×1
asset-score
×1
bcl
×1
boundary-condition
×1
buildings
×1
buildstock-query
×1
daylighting-control
×1
×1
dgi
×1
dhw
×1
energyplus-api
×1
ep-launch
×1
eppy
×1
epw
×1
equest
×1
errors
×1
eso-file
×1
fan
×1
floorspace.js
×1
heating-capacity
×1
hvac
×1
hvac-sizing
×1
ice-rink
×1
import
×1
indoor-temperature
×1
internal-mass
×1
jeplus
×1
×1
measure
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
