Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12867
questions
Tagged
views
no
answers
no
votes
2 hours ago
m19
Openstudio fault creation
openstudio
hvac
openstudio-application
operational-fault
openstudio-measure
4
views
no
answers
no
votes
2 hours ago
ivanadriane
ASHRAE ECB Heat Source for DOAS with terminal WSHP
ashrae-90.1
ecb
baseline
16
views
answer
vote
7 hours ago
JasonGlazer
Climatic Data Summary is coming out blank from Openstudio even with epw file selected
openstudio
epw-file
stat-file
energyplus
summary-report
71
views
answers
no
votes
20 hours ago
Aaron Boranian
Initial temperature unmatching
energyplus
airflow-network
initial-conditions
warmup
10
views
no
answers
vote
22 hours ago
Kashif72
How to get Exfiltration Values (amount of air leaving a zone) in EnergyPlus output files?
energyplus
exfiltration
output-variable
airflow-network
433
views
answer
4
votes
May 5
Denis Bourgeois
… 90.1 2022 requirements for linear thermal bridges
thermal-bridge
tbd
ashrae-90.1
ecb
heat-transfer
175
views
answer
no
votes
May 5
Fred
how can I apply airflow network with ideal air loads?
airflow-network
ideal-loads-air-system
energyplus
natural-ventilation
129
views
answer
votes
May 4
josepsolebonet@telefonica.net
Using Operative Temperature in OpenStudio instead of Air Temperature for the Thermostat
openstudio
measure
operative-temperature
energyplus
thermostat
53
views
answer
votes
May 4
Keigo
control thermal zone temperture by air flow rather than chilled water flow
openstudio
hvac-control
district-cooling
cooling-coil
energyplus
116
views
answer
votes
May 3
lrsanchez510
How to model defrost cycles in EnergyPlus
air-source-heat-pump
defrost
energyplus
dx-coil
output-variable
77
views
no
answers
vote
May 2
Aaron Boranian
Performance Based Curves integration into Design Builder
designbuilder
performance-curve
performance-data
energyplus
73
views
no
answers
no
votes
May 2
Aaron Boranian
BEopt v3.0.1.0 - Error: "Cannot find corresponding design option in design" during Detailed Report generation
beopt
report
summary-report
application-error
bug-report
48
views
no
answers
vote
May 2
Denis Bourgeois
Troubleshooting of a heated floor system
designbuilder
radiant-heating
gshp
hvac-control
low-temperature-radiant
34
views
answer
vote
Apr 30
shorowit
BeOpt - Cooling Energy vs Cooling Fan/Energy
beopt
residential
cooling
fan
results
69
views
answer
vote
Apr 29
Greg Estep
Modeling Centralized Cooling for Multiple Buildings in DesignBuilder
designbuilder
district-cooling
plant-loop
multi-building
66
views
answer
vote
Apr 29
shorowit
at which pressure ACH is reported in EP?
infiltration
energyplus
ach
output-variable
leakage
192
views
answers
votes
Apr 28
Anurag_G
How to Model AHU with DOAS in DesignBuilder?
designbuilder
doas
air-loop
65
views
no
answers
no
votes
Apr 28
Denis Bourgeois
Natural Ventilation not following my inputs on DesignBuilder [closed]
natural-ventilation
designbuilder
bug-report
157
views
no
answers
no
votes
Apr 28
Anurag_G
Modelling core and shell zones under tenant for LEED
designbuilder
leed
ashrae-90.1
baseline
170
views
answer
no
votes
Apr 27
Denis Bourgeois
I want to put mechanical ventilation in my openstudio model
mechanical-ventilation
openstudio
96
views
answers
vote
Apr 25
Fred
AFN Simulation Control Azimuth Angle
energyplus
airflow-network
orientation
geometry
61
views
answer
vote
Apr 25
glinn07
Downgrade E+ on mac
mac-os
installation
energyplus
version
117
views
answer
no
votes
Apr 25
Denis Bourgeois
Glass U-factor in ASHRAE baseline
baseline
openstudio-standards
ashrae-90.1
summary-report
fenestration
71
views
no
answers
no
votes
Apr 25
MarcF
Create typical buiding measure - undefined model standard climate zone [closed]
apply-measure
80
views
no
answers
no
votes
Apr 25
Aaron Boranian
How to Model AHU with DOAS in DesignBuilder? [closed]
designbuilder
doas
air-loop
153
views
answer
vote
Apr 25
Denis Bourgeois
I have a query regarding the energy modelling approach for a data hall.
energyplus
ashrae-90.1
hvac-control
data-center
452
views
answer
vote
Apr 24
Denis Bourgeois
creating glazing construction from scratch
openstudio
glazing
construction
bcl
107
views
no
answers
no
votes
Apr 24
Denis Bourgeois
Heating and cooling load in a baseline model (DesignBuilder)
designbuilder
hvac
ashrae-90.1
baseline
unmet-hours
73
views
answer
votes
Apr 23
Jim Dirkes
Transitioning from eQuest to Trace 3D Plus for LEED Building Energy Modeling
equest
leed
trane-trace
58
views
no
answers
votes
Apr 23
Keigo
Fatal error in zones without floor
energyplus
lighting
bug-report
geometry
5
429
next page »
Careers
Contributors
Tags
energyplus
×13
designbuilder
×8
ashrae-90.1
×6
openstudio
×6
airflow-network
×4
baseline
×4
bug-report
×3
hvac-control
×3
×3
output-variable
×3
summary-report
×3
air-loop
×2
beopt
×2
district-cooling
×2
doas
×2
ecb
×2
geometry
×2
hvac
×2
leed
×2
natural-ventilation
×2
ach
×1
×1
application-error
×1
apply-measure
×1
bcl
×1
construction
×1
cooling
×1
cooling-coil
×1
data-center
×1
defrost
×1
dx-coil
×1
epw-file
×1
equest
×1
exfiltration
×1
fan
×1
fenestration
×1
glazing
×1
gshp
×1
heat-transfer
×1
×1
infiltration
×1
initial-conditions
×1
installation
×1
leakage
×1
lighting
×1
×1
mac-os
×1
measure
×1
×1
multi-building
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
