Help
page!
Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12238
questions
Tagged
views
no
answers
no
votes
2024-05-17 07:49:27 -0500
Burns
[Jupyter] AttributeError: module 'PyFMI' has no attribute 'load_fmu'
conda
pyfmi
import
python
jupyter
17
views
answer
no
votes
2024-05-17 07:28:59 -0500
Burns
energyplus
fmu
energyplus-to-fmu
severe-error
cooling
view
no
answers
no
votes
2024-05-17 06:38:47 -0500
RichardT
2018
iecc
cooling-capacity
heating
heating-capacity
132
views
answer
vote
2024-05-16 13:01:01 -0500
efrainpuerto
ems
energyplus
severe-error
node-connection
ems-control
1k
views
answer
no
votes
2024-05-16 12:38:25 -0500
MJWitte
Error when using PTHP
error
openstudio-application
pthp
ideal-loads-air-system
155
views
answer
vote
2024-05-16 12:34:56 -0500
MJWitte
hvac-template
fan
pthp
energyplus
fatal
7
views
no
answers
no
votes
2024-05-16 11:04:28 -0500
DSMEAEP
Severe Error **HVACTEMPLATE:* objects found, not supported
hvac
error
hvac-template
energyplus
56
views
no
answers
no
votes
2024-05-16 10:40:56 -0500
Burns
error
energyplus
fmpy
fmu
exception
20
views
no
answers
no
votes
2024-05-16 07:54:14 -0500
chloe
trnsys
vrf
15
views
no
answers
no
votes
2024-05-16 06:11:04 -0500
chloe
vrf
openstudio
energyplus
hvac-control
46
views
answer
vote
2024-05-16 05:27:22 -0500
Denis Bourgeois
asset-score
apply-measure
openstudio
openstudio-sdk
27
views
answer
no
votes
2024-05-16 04:19:08 -0500
Craig Simmons
openstudio
energyplus
error
18
views
no
answers
no
votes
2024-05-15 14:57:02 -0500
DSMEAEP
hvac
infiltration
outdoor-air
energyplus
48
views
no
answers
no
votes
2024-05-15 11:59:17 -0500
chloe
plz... help me. how to do openstudio.
openstudio
vrf
energyplus
hvac
101
views
answer
vote
2024-05-15 11:58:11 -0500
Aaron Boranian
fmpy
energyplus
fmu
error
energyplus-to-fmu
26
views
answer
no
votes
2024-05-15 09:39:15 -0500
Craig Simmons
Seeking Advice on HVAC System Template for Mid-Rise Apartment Project
split-system
hvac
33
views
answer
4
votes
2024-05-15 07:32:35 -0500
Burns
idf
energyplus
geometry
eppy
coordinates
14
views
no
answers
vote
2024-05-15 03:59:23 -0500
Alberta Carella
OpenStudio Application support and training
training
89
views
no
answers
vote
2024-05-15 02:39:45 -0500
Roy_Xu
energyplus
daylighting-control
ems
dgi
shading-control
9
views
no
answers
no
votes
2024-05-14 21:37:56 -0500
Marcos Braz
Energy Plus Two water heaters with two source sides in the same loop.
energyplus
hot-water-loop
air-to-water-heat-pump
solar-collector
plant-loop
48
views
answer
votes
2024-05-14 18:15:40 -0500
shorowit
hvac-control
openstudio
vrf
heating-coil
schedule
56
views
no
answers
no
votes
2024-05-14 12:43:32 -0500
sz1980
Python API: Actuators all zero
ems
python-ems
energyplus
python-plugin
ems-control
62
views
answer
no
votes
2024-05-14 07:54:19 -0500
Denis Bourgeois
What is the solution to the SWIG error in this simulation run? I tried adding two measures Add Meter and ExportMetertoCSV.
measures
energyplus
simulation-failure
openstudio
reporting-measure
153
views
no
answers
vote
2024-05-13 14:20:19 -0500
sduncan
openstudio-pat
parametric-analysis-tool
ms-windows
error
49
views
no
answers
vote
2024-05-13 09:33:47 -0500
adrisnnt
DesignBuilder IDF Import problems
designbuilder
idf
energyplus
coordinates
import
100
views
answer
votes
2024-05-13 08:29:17 -0500
Zakaria
energyplus
construction
surfaces
boundary-condition
airflow-network
70
views
no
answers
no
votes
2024-05-12 22:32:32 -0500
YuqngYang
Ice Rink Modeling
ice-rink
energyplus
equest
26
views
answer
no
votes
2024-05-12 15:07:02 -0500
Greg Estep
Design Builder Heating Coil Nominal Capacity
designbuilder
energyplus
heating-coil
heating-capacity
102
views
answer
votes
2024-05-12 09:25:25 -0500
Aaron Boranian
Basic low temperature electric radiant heating
low-temperature-radiant
energyplus
273
views
answer
vote
2024-05-10 19:14:17 -0500
SJ LEE
Nothing in online BCL
bcl
openstudio
measure
5
408
next page »
Careers
Contributors
Tags
energyplus
×20
×9
openstudio
×7
error
×6
hvac
×4
vrf
×4
ems
×3
fmu
×3
coordinates
×2
designbuilder
×2
ems-control
×2
energyplus-to-fmu
×2
fmpy
×2
heating-capacity
×2
heating-coil
×2
hvac-control
×2
hvac-template
×2
idf
×2
import
×2
pthp
×2
severe-error
×2
2018
×1
airflow-network
×1
×1
apply-measure
×1
asset-score
×1
bcl
×1
boundary-condition
×1
conda
×1
construction
×1
cooling
×1
cooling-capacity
×1
daylighting-control
×1
dgi
×1
eppy
×1
equest
×1
exception
×1
fan
×1
fatal
×1
geometry
×1
heating
×1
hot-water-loop
×1
ice-rink
×1
×1
iecc
×1
infiltration
×1
jupyter
×1
×1
measure
×1
measures
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
