Help
page!
Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12183
questions
Tagged
views
no
answers
no
votes
2024-04-27 18:50:49 -0500
cmui
openstudio
openstudio-hpxml
energyplus
28
views
answer
no
votes
2024-04-27 12:46:43 -0500
macumber
Adjusting the building square footage of an existing osm in SketchUp
sketchup-openstudio-plugin
openstudio
geometry
13
views
no
answers
no
votes
2024-04-26 18:14:52 -0500
James_BC
Another Error Using create_typical_building_from_model
comstock
openstudio-sdk
openstudio-standards
16
views
no
answers
votes
2024-04-26 08:27:10 -0500
Zakaria
Defining an Opening Exposed to Outdoor Conditions
energyplus
construction
surfaces
geometry
boundary-condition
12
views
no
answers
no
votes
2024-04-25 21:28:45 -0500
xchen
sizing
energyplus
design-day
heating-coil
doas
9
views
no
answers
no
votes
2024-04-25 15:38:35 -0500
Rezvan
Whole house fan in energyplus
fan
energyplus
residential
mechanical-ventilation
57
views
answer
vote
2024-04-25 11:53:41 -0500
James_BC
comstock
openstudio-sdk
views
no
answers
no
votes
2024-04-25 10:10:40 -0500
Bernard Kim
Having Trouble With Ideal Loads Air System [closed]
ideal-loads-air-system
energyplus
ladybug
zone-sizing
design-day
11
views
no
answers
no
votes
2024-04-25 08:10:54 -0500
ag
How to model gravity ventilators in Design Builder
designbuilder
exhaust-fan
73
views
no
answers
vote
2024-04-25 01:18:58 -0500
Roy_Xu
energyplus
daylighting-control
ems
dgi
shading-control
21
views
no
answers
no
votes
2024-04-24 23:17:12 -0500
zoops
openstudio-results
openstudio-application
error
openstudio
summary-report
76
views
answer
vote
2024-04-24 18:53:06 -0500
James_BC
openstudio-sdk
comstock
33
views
answer
vote
2024-04-24 15:58:50 -0500
andrefsl
external-shading
openstudio
floorspace.js
58
views
answers
vote
2024-04-24 13:51:57 -0500
JasonGlazer
energyplus
version
packaged
source-code
89
views
no
answers
no
votes
2024-04-24 09:52:13 -0500
Aaron Boranian
energyplus
severe-error
warmup
convergence
22
views
no
answers
no
votes
2024-04-24 09:47:07 -0500
Aaron Boranian
openstudio-sketchup-plugin
openstudio
geometry
spaces
energyplus
26
views
no
answers
vote
2024-04-24 05:33:44 -0500
Mariha
Calculation of surface temperatures in the source code
source-code
surface-temperature
long-wave-radiation
multiple-building
17
views
no
answers
no
votes
2024-04-24 02:41:30 -0500
NahidhS
i need to create multiple ports (inlet outlet in a stratification tank), using OpenModelica, with building library ver11.0.0
ports
stratified-tank
open-modelica
18
views
no
answers
vote
2024-04-24 01:19:46 -0500
Irfan
Updated Variable Values Not Reflecting in EnergyPlus Output Files
energyplus
energyplus-api
ems
output-variable
python-ems
18
views
no
answers
vote
2024-04-23 18:28:46 -0500
Aaron Boranian
Sizing warning outside of sizing period
energyplus
sizing
weather-file
design-day
6
views
no
answers
no
votes
2024-04-23 16:22:02 -0500
andrefsl
Overhang and side shades for windows [closed]
external-shading
53
views
answer
vote
2024-04-23 11:22:43 -0500
James_BC
Unable to use ComStock 2024_R1 measures with OS_SDK 3.7
comstock
openstudio-sdk
openstudio-3.7.0
22
views
no
answers
no
votes
2024-04-23 10:26:38 -0500
MapMortar
Is HotWaterEquipment available in the UI
openstudio-sdk
openstudio
district-hot-water
load
14
views
no
answers
no
votes
2024-04-23 05:58:23 -0500
Bedson
Open Loop, Pipework Sizing
openstudio
volume
pipe
plant-loop
17
views
no
answers
vote
2024-04-23 05:53:31 -0500
MatteoMerli
Chiller Heater Modules in OpenStudio
central-heat-pump-system
chiller-heater
plant-loop
openstudio-3.7.0
13
views
no
answers
no
votes
2024-04-22 09:49:20 -0500
Aaron Boranian
radiance measures run-time error
radiance
measures
error
39
views
answer
vote
2024-04-22 03:50:47 -0500
PmP
Cooling Capacity of Air-Chiller Decrease as the Temperature Rises (hottest simulation day)
energyplus
air-chiller
refrigeration-equipment
cooling-capacity
compressor
123
views
answer
no
votes
2024-04-21 12:01:51 -0500
Denis Bourgeois
Simulation Error (OpenStudio)
buildings
construction
errors
openstudio
27
views
answer
votes
2024-04-20 22:31:19 -0500
Ski90Moo
Zone Air Chiller Total Cooling Rate vs Zone Air Chiller Zone Total Cooling Rate
air-chiller
refregeration
warehouse
walkin-cooler
cooling-load
367
views
answer
no
votes
2024-04-20 22:04:46 -0500
Ski90Moo
Is there a way to extract thermal zone and space information to excel?
energyplus
construction
openstudio
summary-report
internal-load
5
407
next page »
Careers
Contributors
Tags
energyplus
×13
openstudio
×9
×5
openstudio-sdk
×5
comstock
×4
×4
construction
×3
design-day
×3
geometry
×3
air-chiller
×2
ems
×2
error
×2
external-shading
×2
×2
×2
openstudio-3.7.0
×2
plant-loop
×2
sizing
×2
source-code
×2
summary-report
×2
boundary-condition
×1
buildings
×1
×1
chiller-heater
×1
compressor
×1
convergence
×1
cooling-capacity
×1
cooling-load
×1
daylighting-control
×1
designbuilder
×1
dgi
×1
district-hot-water
×1
doas
×1
energyplus-api
×1
errors
×1
exhaust-fan
×1
fan
×1
floorspace.js
×1
heating-coil
×1
internal-load
×1
ladybug
×1
load
×1
long-wave-radiation
×1
measures
×1
multiple-building
×1
open-modelica
×1
openstudio-hpxml
×1
openstudio-results
×1
×1
output-variable
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
