Is datapoint.zip an exact copy of the results and all its subfolders? If so, why are there both the results and the subfolders and a compressed version of the results and subfolders?
| 1 | initial version |
Is an exact copy of the datapoint.zipdata_point.zipresults and all its subfolders? run directory? If so, why are there both the results and the subfolders run directory and a compressed version of the results and subfolders?run directory?
Is data_point.zip an exact copy of the run directory? If so, why are there both the run directory and a compressed version of the run directory?
Is there a way to disable the creation of data_point.zip? I'm not running anything on the cloud. but my large runs are taking forever to compress, adding 15+ minutes to run time.
Also, this issue may be exacerbated by this other issue, which does in my case affect Linux as well.
