Help
page!
Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12799
questions
Tagged
77
views
answer
vote
1 hour ago
isac_93
Blinds layer position
lbl-window
venetian-blind
energyplus
fenestration
construction
23
views
no
answers
no
votes
23 hours ago
Denis Bourgeois
Failed to compute arguments measure
openstudio-application
mac-os
openstudio-results
reporting-measure
application-error
18
views
no
answers
no
votes
41 hours ago
ssjjjyyy
DesignSpecification: OutdoorAir: SpaceList giving 0 mechanical ventilation
mechanical-ventilation
energyplus
ventilation
outdoor-air
spaces
40
views
no
answers
no
votes
Mar 28
TiagoVicenteup
Error: EnergyPlus returned a non-zero exit code (1). Check the stdout-energyplus log
fatal
energyplus
openstudio
66
views
answers
no
votes
Mar 28
Denis Bourgeois
OpenStudio: can't calculate zone volume due to not enclosed surfaces
openstudio
severe-error
sketchup
geometry
29
views
answer
no
votes
Mar 28
Ski90Moo
OpenStudio "AirLoop Unitary System" object
airloop
unitary-system
openstudio
outdoor-air
19
views
no
answers
no
votes
Mar 27
nagpalh
How to control mass flow rate at inlet node of ZONEHVAC:BASEBOARD:RADIANTCONVECTIVE:WATER?
baseboard-heater
ems
energyplus
ems-control
hot-water-loop
68
views
answer
no
votes
Mar 27
ericmartinpe
Battery and PV-roof mounted housing modelling in EnergyPlus
energyplus
tutorial
photovoltaic
battery
279
views
answers
votes
Mar 26
BrianLBall
Issue with Local Server on Parametric Analysis Tool (PAT) and Question on Unmet Hours
parametric-analysis-tool
openstudio
server
openstudio-server
openstudio-pat
97
views
answer
no
votes
Mar 26
BrianLBall
PAT 3.9 start server error
pat
openstudio-pat
error
local-server
102
views
answer
no
votes
Mar 26
BrianLBall
Unable to start PAT Server 3.9.0
pat
server
startup
error
openstudio-pat
73
views
no
answers
vote
Mar 25
Zakaria
Inlet Coil Temperature for Air Chiller in EnergyPlus
air-chiller
output-variable
energyplus
hvac
node-connection
49
views
no
answers
no
votes
Mar 25
Aaron Boranian
Confusion with floor heating modelling
openstudio
radiant-heating
openstudio-measure
88
views
answer
vote
Mar 24
ryunnniii
How to calculate EnergyPlus 'Time setpoint not met during occupied heating/cooling'?
unmet-hours
energyplus
summary-report
57
views
answer
no
votes
Mar 24
Aaron Boranian
Shading:Overhang and Shading:Fin tilt
energyplus
shading
geometry
44
views
no
answers
no
votes
Mar 23
huy1912
Fans consumption too high (OpenStudio)
openstudio
fans
vrf
hvac-control
111
views
no
answers
no
votes
Mar 21
yavi828
Could You Help Me To Check My osm Model?
openstudio
388
views
answers
vote
Mar 20
antoineg
Alternatives to Dview
dview
installation
3k
views
answers
6
votes
Mar 20
antoineg
View EnergyPlus results from multiple output files of some specific variable
energyplus
designbuilder
openstudio-resultsviewer
output-variable
29
views
no
answers
no
votes
Mar 20
Aaron Boranian
error euclid extension
euclid
sketchup
error
energyplus
15
views
no
answers
no
votes
Mar 20
tinneadri
error in euclid extension [closed]
euclid
sketchup
error
energyplus
56
views
answer
no
votes
Mar 20
shorowit
Energy use drops but energy bill same
energyplus
electricity
47
views
answer
vote
Mar 19
RobinCris
eio file in v. 9.4 mistake?
eio-file
shade
material
bug-report
energyplus
240
views
answer
no
votes
Mar 19
Greg Collins
The IESVE result from VistaPro remains unchanged. Apache
ies-ve
vista-pro
designbuilder
gbxml
102
views
no
answers
no
votes
Mar 19
divsood04
Is there a way I can access Unmnet hours data to create an agent?
api
website
62
views
answer
no
votes
Mar 19
Petros Dalavouras
DOAS for Dehumidification Paired with RTU for Heating/Cooling
doas
openstudio
dehumidification
air-loop
57
views
no
answers
vote
Mar 19
Aaron Boranian
OpenStudio: What do I have to do to make muy building affected by the exterior temperature?
infiltration
indoor-temperature
openstudio
energyplus
111
views
no
answers
vote
Mar 19
Julien Marrec
Create Baseline (90.10 2010) Measure gives error : OS 3.7.0
measure
openstudio-standards
baseline
schedule
error
18
views
no
answers
no
votes
Mar 18
mariacanoteixido24
What to do to simulate a building that is affected by the outdoor temperature [closed]
infiltrations
openstudio
energyplus
insulation
53
views
no
answers
no
votes
Mar 18
Aaron Boranian
OpenStudio: Adding a second PVAV gives heating coil missing property error
heating-coil
severe-error
energyplus
node-connection
air-loop
5
427
next page »
Careers
Contributors
Tags
energyplus
×16
openstudio
×10
×8
error
×5
openstudio-pat
×3
sketchup
×3
air-loop
×2
designbuilder
×2
euclid
×2
geometry
×2
node-connection
×2
outdoor-air
×2
output-variable
×2
pat
×2
server
×2
severe-error
×2
air-chiller
×1
airloop
×1
api
×1
application-error
×1
baseboard-heater
×1
baseline
×1
battery
×1
bug-report
×1
construction
×1
dehumidification
×1
doas
×1
dview
×1
eio-file
×1
electricity
×1
ems
×1
ems-control
×1
fans
×1
fatal
×1
fenestration
×1
gbxml
×1
heating-coil
×1
hot-water-loop
×1
hvac
×1
hvac-control
×1
ies-ve
×1
indoor-temperature
×1
infiltration
×1
infiltrations
×1
installation
×1
insulation
×1
lbl-window
×1
local-server
×1
mac-os
×1
material
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
