Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12822
questions
Tagged
12
views
no
answers
no
votes
8 hours ago
MaRe
Pat measures don't appear in measure library
pat
measure
98
views
4
answers
votes
17 hours ago
Greg Collins
How do you model minimum and high efficiency DX cooling and heat pump equipment?
dx
hvac
performance-curve
fan
19
views
no
answers
no
votes
36 hours ago
spqr
Specifying Schedule:File path in OSW configuration
energyplus
openstudio
severe-error
schedule
csv-file
23
views
answer
vote
41 hours ago
rraustad
Controller Water coil configuration
controller
openstudio-application
water-coil
hvac-control
58
views
no
answers
votes
Apr 8
DamonHD
Unexpected design-day heat flows vs U-values in simple building
u-value
energyplus
construction
heat-transfer
heating-load
53
views
no
answers
no
votes
Apr 7
Aaron Boranian
Hey folks, I ran into this error while using the CreateDOEPrototypeBuilding measure in OpenStudio . How to solve this problem?
apply-measure
building-envelope
commercial-prototype-building
openstudio
openstudio-standards
22
views
no
answers
no
votes
Apr 7
KLim
Gas-fired Coil vs Hot Water Coil
heating-coil
hot-water-loop
boiler
19
views
no
answers
no
votes
Apr 7
Aaron Boranian
negative coil bypass factor ?
energyplus
severe-error
vrf
29
views
no
answers
vote
Apr 6
Nico001
How to link HX with supply side of condenser loop in DesignBuilder
designbuilder
ground-source-heat-pump
condenser-loop
heat-exchanger
hvac-diagram
151
views
answers
no
votes
Apr 4
josepsolebonet@telefonica.net
Multiple shading control without EMS
shading-control
energyplus
ems-control
25
views
no
answers
no
votes
Apr 4
Hugo Segura
Hi, I'm new to Pat OpenStudio. I'm unable to get values in the Summary Table. Could you help me find the problem?
openstudio-pat
summary
pat
383
views
answers
4
votes
Apr 3
ericmartinpe
Ground Slab Preprocessor Issue
energyplus
slab-preprocessor
severe-error
55
views
answer
vote
Apr 3
Aaron Boranian
EnergyPlus Node Connection Error – “AHU DEMAND INLET NODE” Not Matched to a Controlled Zone
hvac
node-connection
air-loop
energyplus
severe-error
47
views
answer
votes
Apr 3
PmP
EnergyPlus Air-Chiller Heat Balance Query
energy-balance
heat-balance
air-chiller
energyplus
refrigeration-equipment
67
views
answer
votes
Apr 2
shorowit
EPW Stat File References
stat-file
epw-file
weather-file
thermal-resiliency
333
views
answers
votes
Apr 2
Zakaria
Refrigeration system in EnergyPlus
refrigeration
energyplus
thermal-energy-storage
air-chiller
120
views
answer
votes
Apr 2
Zakaria
Zone Air Chiller Total Cooling Rate vs Zone Air Chiller Zone Total Cooling Rate
air-chiller
refregeration
warehouse
walkin-cooler
cooling-load
304
views
answers
votes
Apr 2
Zakaria
Modeling Adjacent Walls with Different Materials
energyplus
construction
material
interzone-wall
77
views
answer
vote
Apr 2
Denis Bourgeois
Validation of fullinteriorandexterior for a sawtooth facade
energyplus
solar-distribution
simple-glazing-system
convexity
output-variable
55
views
no
answers
vote
Apr 2
mattkoch
AirflowNetworkZone setVentilationControlZoneTemperatureSetpointSchedule fails!
openstudio
openstudio-sdk
airflow-network
openstudio-measure
74
views
no
answers
no
votes
Apr 1
Aaron Boranian
CSV Schedule Objects Not Displaying in Model Library Despite Correct Relative Paths
schedules
csv-file
openstudio
import
17
views
no
answers
no
votes
Apr 1
Zaid
CSV Schedules Not Appearing in Model Library Despite Correct Setup [closed]
schedules
csv-file
openstudio
import
59
views
no
answers
no
votes
Apr 1
herman-riley
General beginner help [closed]
energyplus
training
consult
summary-report
65
views
answer
no
votes
Mar 31
Denis Bourgeois
Warning: Zone Not Fully Enclosed, Edge Used More Than Two Times
sketchup-openstudio-plugin
geometry
sketchup
openstudio
43
views
no
answers
no
votes
Mar 31
alireza
how to fix static hourly airflow rate in zonal variable data?
airflow
airflow-network
energyplus
control-zone
output-variable
22
views
no
answers
no
votes
Mar 31
alireza
Zone Air Node Air Flow [closed]
airflow
airflow-network
energyplus
control-zone
output-variable
40
views
no
answers
vote
Mar 31
SZ_T
Add thermochromic material group in OpenStudio Application 1.9
openstudio
dynamic-glazing
energyplus
194
views
no
answers
vote
Mar 31
Ron
Radiant cooling system in EnergyPlus does not produce any sensible cooling?
low-temperature-radiant
condensation
energyplus
hvac-control
119
views
answer
vote
Mar 31
isac_93
Blinds layer position
lbl-window
venetian-blind
energyplus
fenestration
construction
59
views
no
answers
no
votes
Mar 30
Denis Bourgeois
Failed to compute arguments measure
mac-os
openstudio-results
reporting-measure
application-error
5
428
next page »
Careers
Contributors
Tags
energyplus
×16
openstudio
×7
×6
severe-error
×4
air-chiller
×3
airflow-network
×3
construction
×3
csv-file
×3
output-variable
×3
airflow
×2
control-zone
×2
hvac
×2
hvac-control
×2
import
×2
pat
×2
×2
schedules
×2
air-loop
×1
application-error
×1
apply-measure
×1
boiler
×1
building-envelope
×1
×1
condensation
×1
condenser-loop
×1
consult
×1
controller
×1
convexity
×1
cooling-load
×1
designbuilder
×1
dx
×1
dynamic-glazing
×1
ems-control
×1
energy-balance
×1
epw-file
×1
fan
×1
fenestration
×1
geometry
×1
×1
heat-balance
×1
heat-exchanger
×1
heating-coil
×1
heating-load
×1
heat-transfer
×1
hot-water-loop
×1
hvac-diagram
×1
interzone-wall
×1
lbl-window
×1
×1
mac-os
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
