Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12771
questions
Tagged
10
views
no
answers
vote
12 hours ago
hghg
10 CFR part 433 energy performance requirement
ashrae-90.1
baseline
83
views
answer
vote
16 hours ago
Greg Estep
Water to water HP for SHW use
dhw
plant-loop
water-to-water-heat-pump
chilled-water-loop
11
views
no
answers
vote
18 hours ago
Giovanni Miracco
DesignBuilder ASHP with radiant surface - does not maintain the indoor setpoint in winter
ashp
designbuilder
radiant-heating
air-to-water-heat-pump
unmet-hours
29
views
no
answers
vote
Mar 11
Draza
Two Speed DX Cooling Coil Causes Air Loop Details to be Skipped?
openstudio
dx-coil
openstudio-results
openstudio-application
reporting-measure
41
views
no
answers
no
votes
Mar 11
yavi828
The Cooling Rate Is Too Little
openstudio
cooling-rate
ideal-loads-air-system
27
views
answer
vote
Mar 11
JasonGlazer
How to calculate EnergyPlus 'Time setpoint not met during occupied heating/cooling'?
unmet-hours
energyplus
summary-report
52
views
answer
vote
Mar 10
Julien Marrec
Help With Custom Schedule From File
schedules
schedule-set
loads
openstudio
62
views
answer
votes
Mar 10
JasonGlazer
Errors running DOE prototypes through python EPlus
python
doe-prototype-buildings
slab-preprocessor
basement
energyplus
12
views
no
answers
no
votes
Mar 9
annieliesemari
Help With Custom Schedule From File [closed]
schedules
schedule-set
loads
openstudio
79
views
answer
no
votes
Mar 8
A.Pressler
Simple constant mech ventilation
energyplus
mechanical-ventilation
hvac-control
66
views
no
answers
no
votes
Mar 7
dimitra
No mechanical ventilation electricity or losses in Simple Hvac
designbuilder
designbuilder-results-viewer
3k
views
answers
8
votes
Mar 7
angelson
HVAC Template for standard Split AC
openstudio
hvac-template
energyplus
78
views
answer
vote
Mar 7
JMaguire
BeOpt: hot water - gas tank vs gas tankless
tankless
water-heater
beopt
86
views
answer
no
votes
Mar 6
BrianLBall
how to connect to the server for PAT algorithm run
openstudio-pat
sensitivity-analysis
optimization
server
104
views
answer
no
votes
Mar 5
Denis Bourgeois
Can we put different types of windows in OpenStudio EnergyPlus?
openstudio
fenestration
construction
material
36
views
no
answers
vote
Mar 5
Jonny K
DOE Prototypes - All Electric
electrification
openstudio
36
views
answer
no
votes
Mar 5
Greg Estep
Indirect Air side Economizer
economizer
openstudio
energyplus
air-loop
91
views
answer
no
votes
Mar 5
Greg Estep
Plant loop temperatures are getting far too hot
severe-error
energy
energyplus
designbuilder
plant-loop
14
views
no
answers
no
votes
Mar 4
Jej
Can we put different types of windows in OpenStudio EnergyPlus? [closed]
openstudio
fenestration
construction
material
87
views
answer
no
votes
Mar 3
Julien Marrec
ZoneVentilation:WindandStackOpenArea doens't work
energyplus
natural-ventilation
stack-effect
255
views
no
answers
no
votes
Mar 2
Saeed
How OpenStudio and SketchUp Plug-in connection is working?
sketchup
energyplus
openstudio
openstudio-sketchup-plugin
installation
29
views
no
answers
no
votes
Mar 2
Saeed
How OpenStudio and SketchUp Plug-in connection is working? [closed]
sketchup
energyplus
openstudio
installation
22
views
no
answers
no
votes
Mar 2
Saeed
How OpenStudio & SketchUp Plug connects? [closed]
sketchup
energyplus
openstudio
installation
198
views
answer
no
votes
Mar 1
Denis Bourgeois
What is the best way to model linear thermal bridges in EnergyPlus?
thermal-bridge
energyplus
construction
188
views
answers
vote
Feb 27
Petros Dalavouras
The indoor temperature is higher than the outdoor, but the cooling power is 0
openstudio
dual-thermostat
89
views
no
answers
no
votes
Feb 26
Bilal Ahmed
Cooling Tower is storing excess heat the majority of the time
plant-loop
energyplus
warning
condenser-loop
commercial-reference-building
114
views
answer
vote
Feb 26
Julien Marrec
OpenStudio swig errors when applying measures
swig
openstudio
error
openstudio-measure
77
views
no
answers
no
votes
Feb 26
yavi828
The indoor temperature is higher than the outdoor, but the cooling power is 0 [closed]
openstudio
thermostat
26
views
no
answers
no
votes
Feb 26
jmoody
Prototype.CentralAirSourceHeatPump [closed]
openstudio-standards
central-heat-pump-system
apply-measure
openstudio-measure
48
views
no
answers
no
votes
Feb 26
jmoody
apply-measure
openstudio-measure
5
426
next page »
Careers
Contributors
Tags
openstudio
×15
energyplus
×12
×9
construction
×3
designbuilder
×3
×3
installation
×3
openstudio-measure
×3
×3
plant-loop
×3
sketchup
×3
apply-measure
×2
×2
×2
fenestration
×2
loads
×2
material
×2
×2
×2
schedules
×2
schedule-set
×2
unmet-hours
×2
air-loop
×1
×1
ashp
×1
ashrae-90.1
×1
baseline
×1
basement
×1
beopt
×1
chilled-water-loop
×1
×1
condenser-loop
×1
cooling-rate
×1
×1
dhw
×1
dual-thermostat
×1
dx-coil
×1
economizer
×1
electrification
×1
energy
×1
error
×1
hvac-control
×1
hvac-template
×1
natural-ventilation
×1
openstudio-pat
×1
openstudio-results
×1
optimization
×1
python
×1
radiant-heating
×1
reporting-measure
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
