asked 4 years ago
rainbow's avatar
Problem with "Project loose geometry"
I'm drawing a building with SketchUp Pro 2019 + OpenStudio Plugin.
I have a problem with the "Project loose geometry" button, present on the "OpenStudio Plugin" toolbar.
This is the situation before pressing that button: C:\fakepath\Screeshot_07-09-2020_5.PNG
As you can see, there are 11 windows well drawn (they're created by drawing a rectangle by using the "Shapes" button, on the SketchUp toolbar).
Then, after selecting the entire drawing, I press the "Project Loose Geometry" button, I select the option "Project Selected Loose Geometry".
Now, what I obtain is this: C:\fakepath\Screeshot_07-09-2020_6.PNG
So, a window remains unaltered, after executing the "Project Loose Geometry".
My problem is similar to this, but it seems no one found a solution.
Is there someone who could help me?
Thank You!
As you can see, there are 11 windows well drawn (they're created by drawing a rectangle by using the "Shapes" button, button on the SketchUp toolbar).
Then, after selecting the entire drawing, I press the "Project Loose Geometry" button, and then I select the option "Project Selected Loose Geometry".Geometry" option.
So, unfortunately, a window remains unaltered, after executing the "Project Loose Geometry".
My problem is similar to this, but and it seems no one found a solution.
Is there someone anyone who could help me?
Thank You!
As you can see, there are 11 windows well drawn (they're created by drawing a rectangle by using the "Shapes" button on the SketchUp toolbar).
Then, after selecting the entire drawing, I press the press the "Project Loose Geometry" button, Geometry" button, and then I select the "Project Selected Loose Geometry" Geometry" option.
My problem is similar to this, and it seems no one found a solution.
Is there anyone who could help me?
Thank You!
As you can see, there are 11 windows well drawn (they're (each of them is created by drawing a rectangle by using the "Shapes" button on the SketchUp toolbar).
Then, after selecting the entire drawing, I press the "Project Loose Geometry" button, and then I select the "Project Selected Loose Geometry" option.
Thank You!
As you can see, there are 11 windows (each of them is created by drawing a rectangle by using the "Shapes" button on the SketchUp toolbar).
Thank You!
