I have been having problem with openstudio that it just "randomly" (random as I couldn't figure out why and couldn't find any specific thing I do related to this issue) goes straight into error after starting a run. The log file shows the weather file and measures are not there, thus the error. But these are in the model when I first open the file. At some point (when i click run?), they are just gone. It is annoying because then I need to restart the program (it won't let me select the weather file within the same session), select the weather file and add back in all the measures.
I'm not sure if anyone else has the same problem. Is it a computer setting (I use windows 10) or something. I have had this issue with earlier versions of openstudio as well as the more recent v2.8.1.
