I completed a model using the following element (and all the related objects):
- One AirTerminal:SingleDuct:VAV:HeatandCool:Reheat
- Boiler:HotWater
- Chiller:Electric:EIR
- CoolingTower:TwoSpeed
- WaterHeater:Mixed
The model run correctly and this is the basic case, now I want to implement a model that use a Internal Combustion Engine and an Absorption Chiller to cover the basic load. I will resize the Boiler and the Chiller to cover the peak load.
I thought to use Generator:MicroCHP and Chiller:Absorption, but I didn't find and example and this is the first time that I am trying to build a system with more energy sources.
My idea is to create the object Generator:MicroCHP and Chiller:Absorption with their loop and insert in parallel in the existing loop. I am thinking in a correct way or I am missing some fundamental aspects?
It's possible to use a heat exchanger for the DHW loop instead of a Boiler?
Thank you!
Andrea
