EnergyPlus Error initiating text editor
To whom it may concern,
I have worked with EnergyPlus v.25.1.0 for a couple of months. A couple of days ago, I tried to check some elements using the Edit - Text Editor button on the EP-Launch. But, I got the following message:
"Error editing text editor. This is likely due to the text editor program being deleted or moved. Please use the VIEW OPTIONS menu to select a new TEXT EDITOR program."
I searched online for a solution. I clicked on View menu, chose Options, looked for Text Editor Options and selected Auto Find. This solved the problem...for a couple of seconds. Then, my Antivirus closed the file and placed the EnergyPlus.exe file into quarantine. I searched again for another solution. Finally, I downloaded EnergyPlus v.25.2.0 and clicked again the Edit - Text Editor button on the EP-Launch. Nevertheless, I got the same message as before.
I am not sure what could be the following steps to follow. Any comments or suggestions will be highly appreciated!
José Luis Bermúdez Alcocer, Ph.D.
