Hi there! Please sign in
help
tags
users
badges
ALL
UNANSWERED
RSS
Sort by »
date
activity ▼
answers
votes
12831
questions
Tagged
6
views
no
answers
no
votes
1 hour ago
IanVG
PNNL Prototype Scorecards versus DOE Building Prototype
openstudio-standards
schedules
prototype
39
views
answer
votes
26 hours ago
shorowit
Issue Extracting Data from ESO files and CSV-to-EPW Conversion Using Python
eso-file
csv
python
energyplus
21
views
no
answers
no
votes
32 hours ago
Aaron Boranian
geometric error updating from v. 8.5 to 9.6
geometry
energyplus
idf-version-updater
warning
59
views
answer
no
votes
35 hours ago
Denis Bourgeois
where can I find Construction:AirBoundary in Openstudio
openstudio
openstudio-application
construction
air-wall
boundary-condition
90
views
answer
no
votes
35 hours ago
BrianLBall
Pat measures don't appear in measure library
pat
measure
openstudio-pat
13
views
no
answers
no
votes
44 hours ago
walk_er
Issue Extracting Data from ESO files and CSV-to-EPW Conversion Using Python [closed]
eso-file
csv
python
energyplus
28
views
no
answers
no
votes
Apr 14
antonszilasi
Open Studio water heater direct query failing.
openstudio
water-heater
dhw
energyplus
306
views
5
answers
6
votes
Apr 13
Keigo
How do you model minimum and high efficiency DX cooling and heat pump equipment?
dx
hvac
performance-curve
fan
20
views
no
answers
vote
Apr 12
Keigo
Valid range of inlet air WB for cooling towers
energyplus
cooling-tower
wet-bulb
warning
performance-data
50
views
answer
vote
Apr 11
shorowit
Specifying Schedule:File path in OSW configuration
energyplus
openstudio
severe-error
schedule
csv-file
38
views
no
answers
no
votes
Apr 11
Novak Popovic
Separate houses- EnergyPlus
energyplus
sketchup
multi-building
residential-modeling
31
views
no
answers
no
votes
Apr 10
mj
OpenStudio - How do I reset the origin of the grid in 3D view?
openstudio
geometry
33
views
answer
vote
Apr 9
rraustad
Controller Water coil configuration
controller
water-coil
hvac-control
126
views
no
answers
votes
Apr 8
DamonHD
Unexpected design-day heat flows vs U-values in simple building
u-value
energyplus
construction
heat-transfer
heating-load
97
views
no
answers
no
votes
Apr 7
Aaron Boranian
Hey folks, I ran into this error while using the CreateDOEPrototypeBuilding measure in OpenStudio . How to solve this problem?
apply-measure
building-envelope
commercial-prototype-building
openstudio
31
views
no
answers
no
votes
Apr 7
KLim
Gas-fired Coil vs Hot Water Coil
heating-coil
hot-water-loop
boiler
27
views
no
answers
no
votes
Apr 7
Aaron Boranian
negative coil bypass factor ?
energyplus
severe-error
vrf
57
views
no
answers
vote
Apr 6
Nico001
How to link HX with supply side of condenser loop in DesignBuilder
designbuilder
ground-source-heat-pump
condenser-loop
heat-exchanger
hvac-diagram
164
views
answers
no
votes
Apr 4
josepsolebonet@telefonica.net
Multiple shading control without EMS
shading-control
energyplus
ems-control
42
views
no
answers
no
votes
Apr 4
Hugo Segura
Hi, I'm new to Pat OpenStudio. I'm unable to get values in the Summary Table. Could you help me find the problem?
openstudio-pat
summary
pat
391
views
answers
4
votes
Apr 3
ericmartinpe
Ground Slab Preprocessor Issue
energyplus
slab-preprocessor
severe-error
73
views
answer
vote
Apr 3
Aaron Boranian
EnergyPlus Node Connection Error – “AHU DEMAND INLET NODE” Not Matched to a Controlled Zone
hvac
node-connection
air-loop
energyplus
severe-error
53
views
answer
votes
Apr 3
PmP
EnergyPlus Air-Chiller Heat Balance Query
energy-balance
heat-balance
air-chiller
energyplus
refrigeration-equipment
72
views
answer
votes
Apr 2
shorowit
EPW Stat File References
stat-file
epw-file
weather-file
thermal-resiliency
343
views
answers
votes
Apr 2
Zakaria
Refrigeration system in EnergyPlus
refrigeration
energyplus
thermal-energy-storage
air-chiller
124
views
answer
votes
Apr 2
Zakaria
Zone Air Chiller Total Cooling Rate vs Zone Air Chiller Zone Total Cooling Rate
air-chiller
refregeration
warehouse
walkin-cooler
cooling-load
309
views
answers
votes
Apr 2
Zakaria
Modeling Adjacent Walls with Different Materials
energyplus
construction
material
interzone-wall
89
views
answer
vote
Apr 2
Denis Bourgeois
Validation of fullinteriorandexterior for a sawtooth facade
energyplus
solar-distribution
simple-glazing-system
convexity
output-variable
69
views
no
answers
vote
Apr 2
mattkoch
AirflowNetworkZone setVentilationControlZoneTemperatureSetpointSchedule fails!
openstudio
openstudio-sdk
airflow-network
openstudio-measure
96
views
no
answers
no
votes
Apr 1
Aaron Boranian
CSV Schedule Objects Not Displaying in Model Library Despite Correct Relative Paths
schedules
csv-file
openstudio
import
5
428
next page »
Careers
Contributors
Tags
energyplus
×16
openstudio
×7
×5
severe-error
×4
air-chiller
×3
construction
×3
csv
×2
csv-file
×2
eso-file
×2
geometry
×2
hvac
×2
openstudio-pat
×2
×2
pat
×2
python
×2
×2
schedules
×2
warning
×2
airflow-network
×1
air-loop
×1
air-wall
×1
apply-measure
×1
boiler
×1
boundary-condition
×1
building-envelope
×1
×1
condenser-loop
×1
controller
×1
convexity
×1
cooling-load
×1
cooling-tower
×1
designbuilder
×1
dhw
×1
dx
×1
ems-control
×1
energy-balance
×1
epw-file
×1
fan
×1
×1
heat-balance
×1
heat-exchanger
×1
heating-coil
×1
heating-load
×1
heat-transfer
×1
hot-water-loop
×1
hvac-control
×1
hvac-diagram
×1
idf-version-updater
×1
import
×1
interzone-wall
×1
The
Unmet Hours
and
Big Ladder
Powered by
here is how
dummy
