The best approach is to describe the window in detail with built-up layers of materials and a frame so that they match the requirement in the standard. An alternative to that is to use WindowMaterial:SimpleGlazingSystem which uses an algorithm to create an equivalent single layer window. This algorithm is described in the engineering reference.
