Clarify what you mean by "place more and more electric equipment into the zone". Do you actually mean increasing your fraction lost? If that's the case, increasing your fraction lost would increase your gas consumption. By default the Fraction Lost is 0, and increasing it to .5 would indeed increase your gas consumption. The Fraction Lost is multiplied by the total energy consumed by the equipment to give the amount of heat which is 'lost' that does not impact the energy balance.
Clarify what you mean by "place more and more electric equipment into the zone". Do you actually mean increasing your fraction lost? If that's the case, increasing Increasing your fraction lost would increase your gas consumption. By default the Fraction Lost is 0, and increasing it to .5 would indeed increase your gas consumption. The Fraction Lost is multiplied by the total energy consumed by the equipment to give the amount of heat which is 'lost' that does not impact the energy balance.
Clarify what you mean by "place more and more electric equipment into the zone". Do you actually mean increasing your fraction lost? Increasing your fraction lost would increase your gas consumption. By default the Fraction Lost is 0, and increasing it to .5 would indeed increase your gas consumption. The Fraction Lost is multiplied by the total energy consumed by the equipment to give the amount of heat which is 'lost' that does not impact the energy balance.balance. See E+ document here
| 4 | No.4 Revision |
Clarify what you mean by "place more and more electric equipment into the zone". Do you actually mean increasing your fraction lost? Increasing your fraction lost would increase your gas consumption. By default the Fraction Lost is 0, and increasing it to .5 would indeed increase your gas consumption. The Fraction Lost is multiplied by the total energy consumed by the equipment to give the amount of heat which is 'lost' that does not impact the energy balance. See E+ document documentation here
| 5 | No.5 Revision |
Clarify what you mean by "place more and more electric equipment into the zone". Do you actually mean increasing your fraction lost? Increasing your fraction lost would increase your gas consumption. By default the Fraction Lost is 0, and increasing it to .5 would indeed increase your gas consumption. The Fraction Lost is multiplied by the total energy consumed by the equipment to give the amount of heat which is 'lost' that does not impact the energy balance. See E+ documentation here for clarification.
| 6 | No.6 Revision |
Clarify what you mean by "place more and more electric equipment into the zone". Do you actually mean increasing your fraction lost? Increasing your fraction lost would increase your gas consumption. By default the Fraction Lost is 0, and increasing it to .5 would indeed increase your gas consumption. See E+ documentation here for clarification.
| 7 | No.7 Revision |
Clarify what you mean by "place more and more electric equipment into the zone". Do you actually mean increasing your fraction lost? By default the Fraction Lost is 0, and 0 which indicates all the equipment power is given off in the zone, so increasing it to .5 would indeed increase your gas consumption. See E+ documentation here for clarification.
| 8 | No.8 Revision |
Clarify what you mean by "place more and more electric equipment into the zone". Do you actually mean increasing your fraction lost? By default the Fraction Lost is 0 which indicates all the equipment power is given off in the zone, so increasing it to .5 would indeed increase your gas consumption. consumption since the .5 means that half the energy is 'lost' or converted. See E+ documentation here for clarification.
| 9 | No.9 Revision |
Clarify what you mean by "place more and more electric equipment into the zone". Do you actually mean increasing your fraction lost? By default the Fraction Lost is 0 which indicates all the equipment power is given off in the zone, so increasing it to .5 would indeed increase your gas consumption since the .5 means that half the energy is 'lost' or converted. See E+ documentation here for clarification.
| 10 | No.10 Revision |
