Hi there! Can anyone please tell me how to fix this please?
** Severe ** <root>[AirLoopHVAC:UnitarySystem][Unitary - Single Speed DX cooling - Cycling - Elec reheat][no_load_supply_air_flow_rate_control_set_to_low_speed] - "SupplyAirFlowRate" - Failed to match against any enum values.
the idf snippet is:
AirLoopHVAC:UnitarySystem,
Unitary - Single Speed DX cooling - Cycling - Elec reheat, !- Name
SetPoint, !- Control Type
Thermal Zone 1, !- Controlling Zone or Thermostat Location
None, !- Dehumidification Control Type
, !- Availability Schedule Name
Node 9, !- Air Inlet Node Name
Node 3, !- Air Outlet Node Name
Fan:OnOff, !- Supply Fan Object Type
Fan On Off 8, !- Supply Fan Name
BlowThrough, !- Fan Placement
, !- Supply Air Fan Operating Mode Schedule Name
, !- Heating Coil Object Type
, !- Heating Coil Name
0.4, !- DX Heating Coil Sizing Ratio
Coil:Cooling:DX:SingleSpeed, !- Cooling Coil Object Type
1 Spd DX Clg Coil 7, !- Cooling Coil Name
No, !- Use DOAS DX Cooling Coil
2, !- Minimum Supply Air Temperature
SensibleOnlyLoadControl, !- Latent Load Control
Coil:Heating:Electric, !- Supplemental Heating Coil Object Type
Elec Htg Coil 15, !- Supplemental Heating Coil Name
SupplyAirFlowRate, !- Cooling Supply Air Flow Rate Method
Autosize, !- Cooling Supply Air Flow Rate
, !- Cooling Supply Air Flow Rate Per Floor Area
, !- Cooling Fraction of Autosized Cooling Supply Air Flow Rate
, !- Cooling Supply Air Flow Rate Per Unit of Capacity
None, !- Heating Supply Air Flow Rate Method
, !- Heating Supply Air Flow Rate Per Floor Area
, !- Heating Fraction of Autosized Heating Supply Air Flow Rate
, !- Heating Supply Air Flow Rate Per Unit of Capacity
SupplyAirFlowRate, !- No Load Supply Air Flow Rate Method
Autosize, !- No Load Supply Air Flow Rate
, !- No Load Supply Air Flow Rate Per Floor Area
, !- No Load Fraction of Autosized Cooling Supply Air Flow Rate
, !- No Load Fraction of Autosized Heating Supply Air Flow Rate
1, !- No Load Supply Air Flow Rate Per Unit of Capacity During Cooling Operation
, !- No Load Supply Air Flow Rate Per Unit of Capacity During Heating Operation
SupplyAirFlowRate, !- No Load Supply Air Flow Rate Control Set To Low Speed
21, !- Maximum Supply Air Temperature
, !- Maximum Outdoor DryBulb Temperature for Supplemental Heater Operation
0, !- Outdoor DryBulb Temperature Sensor Node Name
0; !- Ancillary OnCycle Electric Power
I tried allready Variables and Scalar values for "No Load Supply Air Flow Rate Control Set To Low Speed", but the error stays the same. Or do you recommend me another AC Element or do do you have any ideas to solve this maybe?
thx in advance and looking forward to get a running FMU soon xD.
