Issue with fluctuating chilled water loop temperature in a trajectory
I tried running two test cases here
1, Fluctuating the chilled water loop setpoint temperature within a trajectory. Ex. randomize the temperature in the range of [6, 11] C at each timestep.
  1. Simulate 6 times from [6,11] C, where a similar setpoint temperature is used for every trajectory. Ex. 6C for trajectory 1, 7C for trajectory 2, ...
Despite achieving the desired setpoint at times, the HVAC values for test case 1 are inconsistent with test case 2.
Has anyone faced this issue and how to overcome it
test case 1
testcase1
test case 2
testcase2
  1. timestep. 2. Simulate 6 times from [6,11] C, where a similar setpoint temperature is used for every trajectory. Ex. 6C for trajectory 1, 7C for trajectory 2, ...
test case 1
testcase1
test case 2
testcase2
1, Fluctuating the chilled water loop setpoint temperature within a trajectory. Ex. randomize the temperature in the range of [6, 11] C at each timestep. 2. Simulate 6 times from [6,11] C, where a similar setpoint temperature is used for every trajectory. Ex. 6C for trajectory 1, 7C for trajectory 2, ...
Has anyone faced this issue and how to overcome itit?
test case 1
testcase1
test case 2
testcase2
Has anyone faced this issue and how to overcome it?
test case 1
testcase1
test case 2
testcase2
