I am trying to study wind driven natural ventilation for a high rise 22-floor apartment with airflow network. the building is located on site with higher altitude from the weather station data.
- my case : building located on highland region, about 55m from sea level
- weather data : Site:Location Elevation is at 3.7m from sea level
- model description : since floor plans are typical, only the middle portion of the building is modelled (in this case the whole floor plan at 10th floor).
- in modeling the geometry, should i lift the whole building geometry 55m up from the "origin (0,0,0)" point to account for the elevation difference?
- what is the best practice on modeling geometry with similar case? since pressure, temperature and wind velocity varies with height as described in detail here
thanks!
