for more detailed error message -
* Warning * In calculating the design coil UA for Coil:Cooling:Water THERMAL ZONE: A013 COOLING COIL
* ~~~ * the outlet chilled water design enthalpy is greater than the inlet air design enthalpy.
* ~~~ * To correct this condition the design chilled water flow rate will be increased from 2.49319E-006
* ~~~ * to 6.01354E-006 m3/s
* Severe * Calculation of cooling coil design UA failed for coil THERMAL ZONE: A013 COOLING COIL
* ~~~ * Bad starting values for UA
* ~~~ * Coil design UA set to 245.887736 [W/C]
