Hello everyone!
In RefrigeratedWarehouse.idf example where the aim to model a warehouse with refrigeration equipment. The Refrigeration:AirChiller object is used to model the cooling air system. OutdoorAir:Node object is defined under the Refrigeration:CONDENSER LowTempSystem CondenserNode (Fig.1), this object is used to defines the outdoor air temperature and humidity conditions. This object is then used in Refrigeration:Condenser:AirCooled at Air Inlet Node Name or Zone Name (Fig.2).
Fig.1
Fig.2
Upon examining the outputs, particularly System Node Setpoint Temperature for the Refrigeration:CONDENSER LowTempSystem CondenserNode node has a value equal to -1000°C (Fig.3). Is this normal, cause I was expecting a temperature close the condensing temperature since the nodes defines the outdoor envirement air conditions.
I've encountered a similar issue in my own model, where I'm attempting to replicate a 38m3 cold room.
Any insights into why this might be happening would be greatly appreciated.
Fig.3
