holle everyone, I have just started learning Open Studio and encountered some problems while conducting simulations. The error report is presented below. May I ask what is the reason for this situation? How should it be modified?
SProgram Version,EnergyPlus, Version 23.1.0-87ed9199d4, YMD=2023.12.25 20:48, *** Beginning Zone Sizing Calculations * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 07:15 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 1 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 07:45 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 1 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 08:15 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 1 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 08:45 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 1 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 09:15 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 1 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 17:15 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 1 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 17:45 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 1 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 18:15 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 1 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 18:45 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 1 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 19:15 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 1 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 12:45 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 2 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 13:15 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 2 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 13:45 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 2 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 14:15 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 2 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 17:15 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 2 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 17:45 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 2 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 18:45 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 2 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 19:15 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 2 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 08:15 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 3 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 14:15 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 6 * Warning * ProcessScheduleInput: DecodeHHMMField, Invalid "until" field value is not a multiple of the minutes for each timestep: 14:45 * ~~~ * Other errors may result. Occurred in Day Schedule=SCHEDULE DAY 6 * Warning * ProcessScheduleInput: Schedule:Constant="ALWAYS OFF DISCRETE", Blank Schedule Type Limits Name input -- will not be validated. * Warning * ProcessScheduleInput: Schedule:Constant="ALWAYS ON CONTINUOUS", Blank Schedule Type Limits Name input -- will not be validated. * Warning * GetHTSurfaceData: Surfaces with interface to Ground found but no "Ground Temperatures" were input. * ~~~ * Found first in surface=SURFACE 20 * ~~~ * Defaults, constant throughout the year of (18.0) will be used. * Warning * GetSurfaceData: Construction INTERIOR WINDOW of interzone surface SUB SURFACE 28 does not have the same materials in the reverse order as the construction INTERIOR WINDOW of adjacent surface SUB SURFACE 48 * ~~~ * or the properties of the reversed layers are not correct due to differing layer front and back side values * ~~~ * ...but Nominal U values are similar, diff=[0.0000] ... simulation proceeds. * ~~~ * ...if the two zones are expected to have significantly different temperatures, the proper "reverse" construction should be created. * ~~~ * ...this problem for this pair will not be reported again. * Warning * CalculateZoneVolume: 2 zones are not fully enclosed. For more details use: Output:Diagnostics,DisplayExtrawarnings; * Warning * CheckUsedConstructions: There are 4 nominally unused constructions in input. * ~~~ * For explicit details on each unused construction, use Output:Diagnostics,DisplayExtraWarnings; * Warning * GetSimpleAirModelInputs: ZoneInfiltration:DesignFlowRate="SPACE 107 189.1-2009 - SECSCHL - KITCHEN - CZ4-8 INFILTRATION", Design Flow Rate Calculation Method specifies Flow Rate per Exterior Surface Area, but Exterior Surface Area = 0. 0 Infiltration will result. * Severe * Convergence error in SolveForWindowTemperatures for window SUB SURFACE 26 * ~~~ * During Warmup & Sizing, Environment=BEIJING ANN CLG .4% CONDNS DB=>MWB, at Simulation time=07/21 05:10 - 05:20 * Fatal * Program halted because of convergence error in SolveForWindowTemperatures for window SUB SURFACE 26 ...Summary of Errors that led to program termination: ..... Reference severe error count=1 ..... Last severe error=Convergence error in SolveForWindowTemperatures for window SUB SURFACE 26 *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages.
*** ===== Final Error Summary ===== *** The following error categories occurred. Consider correcting or noting. *** Nominally Unused Constructions *** ..The nominally unused constructions warning is provided to alert you to potential conditions that can cause *** ..extra time during simulation. Each construction is calculated by the algorithm indicated in the HeatBalanceAlgorithm *** ..object. You may remove the constructions indicated (when you use the DisplayExtraWarnings option).
*** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 28 Warning; 1 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 28 Warning; 1 Severe Errors; Elapsed Time=00hr 00min 0.20sec
