Hi!
I'm modelling an AHU (Air Handling Unit) which has a system called "heat pipe" as you can see in the picture below.
C:\fakepath\Esquema clima .png
I've been looking for information on how to model this type of system but haven't found anything. Any ideas?
I've seen that in EnergyPlus there is the object: CoilSystem:CoolingWater:HeatExchangerAssiste, which works similarly but i haven't found it in OpenStudio.
