I'm using ResStock 3.1.0 to model HVAC electrification in Maine.
Screenshots from the national_upgrades.yml config file for ASHP and MSHP upgrades are below.
Just looking at the option: Parameter|Option lines, it looks like you need to specify HVAC Heating Efficiency, which specifies the type and efficiency of equipment. But you also need to specify HVAC Cooling Efficiency|Heat Pump?
The ResStock development team is addressing "fixing ducts + HVAC inconsistencies," to add options like Ducted Heat Pump and Non-Ducted Heat Pump for the HVAC Cooling Efficiency parameter (among other changes?). This is in the develop branch of ResStock, however.
To model a heat pump upgrade in released version 3.1.0, is it sufficient to specify HVAC Heating Efficiency|XXX and HVAC Cooling Efficiency|Heat Pump?
Or do I need to also specify HVAC Cooling Type|Heat Pump, HVAC Heating Type|Ducted Heat Pump or Non-Ducted Heat Pump, etc.
