I'm trying to implement a research paper where they used Deep Reinforcement Learning to control the Setpoint of Chilled Water Temperature [6-9°C] and the Setpoint of Cooling Water Temperature [29-31°C].
I'm trying to implement this on an IDF file and having trouble identifying the right actuator to control. I've cut the list of actuators from .edd file to the following. Which do I have to use from them to control those two values?
CHILLED WATER LOOP SUPPLY INLET NODE,System Node Setpoint,Temperature Setpoint,[C]
CHILLED WATER LOOP SUPPLY OUTLET INLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CHILLED WATER LOOP SUPPLY OUTLET NODE,System Node Setpoint,Temperature Setpoint,[C]
CHILLED WATER LOOP CHILLER BYPASS INLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CHILLED WATER LOOP CHILLER BYPASS OUTLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CHILLED WATER LOOP PRIMARY PUMP OUTLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CHILLED WATER LOOP DEMAND INLET NODE,System Node Setpoint,Temperature Setpoint,[C]
CHILLED WATER LOOP DEMAND BYPASS PIPE INLET NODE,System Node Setpoint,Temperature Setpoint,[C]
CHILLED WATER LOOP DEMAND BYPASS PIPE OUTLET NODE,System Node Setpoint,Temperature Setpoint,[C]
CHILLED WATER LOOP DEMAND OUTLET INLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CHILLED WATER LOOP DEMAND OUTLET NODE,System Node Setpoint,Temperature Setpoint,[C]
CHILLED WATER LOOP SECONDARY PUMP INLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CHILLED WATER LOOP SECONDARY PUMP OUTLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CHILLED WATER LOOP COIL BYPASS INLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CHILLED WATER LOOP COIL BYPASS OUTLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CONDENSER WATER LOOP SUPPLY INLET NODE,System Node Setpoint,Temperature Setpoint,[C]
CONDENSER WATER LOOP SUPPLY OUTLET INLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CONDENSER WATER LOOP SUPPLY OUTLET NODE,System Node Setpoint,Temperature Setpoint,[C]
CONDENSER WATER LOOP CONSTANT PUMP OUTLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CONDENSER WATER LOOP COOLING TOWER BYPASS INLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CONDENSER WATER LOOP COOLING TOWER BYPASS OUTLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CONDENSER WATER LOOP CHILLER BYPASS INLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CONDENSER WATER LOOP CHILLER BYPASS OUTLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CONDENSER WATER LOOP DEMAND INLET NODE,System Node Setpoint,Temperature Setpoint,[C]
CONDENSER WATER LOOP DEMAND INLET OUTLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CONDENSER WATER LOOP DEMAND BYPASS PIPE INLET NODE,System Node Setpoint,Temperature Setpoint,[C]
CONDENSER WATER LOOP DEMAND BYPASS PIPE OUTLET NODE,System Node Setpoint,Temperature Setpoint,[C]
CONDENSER WATER LOOP DEMAND OUTLET INLET WATER NODE,System Node Setpoint,Temperature Setpoint,[C]
CONDENSER WATER LOOP DEMAND OUTLET NODE,System Node Setpoint,Temperature Setpoint,[C]
