Hi everybody,
I am trying to make a air loop with a water coil to control the humidity. I found the 5ZoneCoolingPanelBaseboard.idf case in the energyplus example.
It is said in this example that the humidity is control to be below 50% for the space 2-1. This is normally done with a humidistat and a set point manager.
But when we run and check the results of this example, the humidity is not controlled and part time over 50 %.
Is it normal ?
