Since the interpretation says that "The unmet hours for the proposed building shall not exceed the unmet hours for the baseline building by more than 50 hours. If the unmet hours of the proposed building does exceed that of the baseline building by more than 50, incrementally decreasing the simulated capacities of the baseline building will result in an increase in the unmet hours of the baseline building".
What is the correct way through which we can reduce the baseline system capacity? Can we use the sizing factor smaller than 1 like 0.78 to reduce the baseline capacity ?
