Cooling Loads not showing up under "Results Summary Section"
I have tried to make my first fairly advanced OpenStudio model. However, even though the simulation runs with no "errors", the cooling loads do not show up under "HVAC Load Profiles". I will upload photos of all my loops below. In addition to this, in my .eio file, the Cooling Coil Capacity for all 4 of my coils are 0. I do not know why this is the case, perhaps because my unit ventilator constant cooling has "Coil:Cooling:Water" data all autosized? I've been working on trying to fix this issue for a week now, and any help would be appreciated.
