Controller Mechanical Ventilation and Latent effectiveness of air-to-air plate HX
Good afternoon, I am performing the following installation:
https://unmethours.com/question/94380/errors-with-heating-and-other-components/
and when I receive the data, which may be possibly incorrect I've been looking at the errors, almost all of them are with the DOAS installation. Next I show you the error code received and some data of the installation.
* Warning * GetOAControllerInputs: Controller:MechanicalVentilation="CONTROLLER MECHANICAL VENTILATION 1 * ~~~ * Cannot locate a matching DesignSpecification:ZoneAirDistribution object for Zone="ZT BAÑO". * ~~~ * Using default zone air distribution effectiveness of 1.0 for heating and cooling.
* Warning * HeatExchanger:AirToAir:SensibleAndLatent ="AIR-TO-AIR PLATE HX" latent effectiveness is less than zero. Check the following inputs. * ~~~ * ...Latent Effectiveness at 100% Cooling Air Flow = 0.68 * ~~~ * ...Latent Effectiveness at 75% Cooling Air Flow = 0.73 * ~~~ * ...Latent effectiveness reset to zero and the simulation continues. * ~~~ * ...Heat Exchanger Air Volume Flow Ratio = 4.53
Could someone tell me how to fix the error?
Thanks in advance
image descriptionimage descriptionimage description
Thanks in advance
