Trouble with the HVAC setting
Dear all,
I am simulation a building using Openstudio and E+. The HVAC system is composted by a multifunctional heat pump (it makes simultaneously heating and cooling), a ground water condenser and cooled beams as air terminals that provided both the cooling and the heating in the zones. I have used the CentralHeatPumpSystem to simulate the multifunctional heat pump. I have used the PlantComponent:TemperatureSource to simulate the ground water used as condenser I have used the FourPipeInduction Air terminals to simulate the cooled beams. I can't understand why the simulation doesn't work properly and I have problems with the sizing of the objects and the convergence of the temperature.
Has someone of you any idea how should I do to solve this issue? I attach the idf below.
Thank you very much
Have a nice day
Elena
Dear all,
Thank you very much
Have a nice day
Elena
Dear all,
Thank you very much
Have a nice day
Elena
part of the error message:
*** Beginning System Sizing Calculations *** Beginning Plant Sizing Calculations * Warning * In calculating the design coil UA for Coil:Cooling:Water HW CHW FOUR PIPE INDUCTION TERMINAL CHW CLG COIL 2 * ~~~ * the apparatus dew-point is below the coil design inlet water temperature; * ~~~ * the coil outlet design conditions will be changed to correct the problem. * ~~~ * The initial design conditions are: Tair,in = 25.9833 * ~~~ * Wair,in = 9.554298E-003 * ~~~ * Twater,in = 7.2200 * ~~~ * Tair,out = 9.2200 * ~~~ * Wair,out = 6.585921E-003 * ~~~ * The revised design conditions are: Tair,out = 9.2195 * ~~~ * Wair,out = 6.586107E-003 * Warning * In calculating the design coil UA for Coil:Cooling:Water HW CHW FOUR PIPE INDUCTION TERMINAL CHW CLG COIL * ~~~ * no apparatus dew-point can be found for the initial entering and leaving conditions; * ~~~ * the coil outlet design conditions will be changed to correct the problem. * ~~~ * The initial design conditions are: Tair,in = 25.9845 * ~~~ * Wair,in = 1.167724E-002 * ~~~ * Twater,in = 7.2200 * ~~~ * Tair,out = 9.2200 * ~~~ * Wair,out = 6.585921E-003 * ~~~ * The revised design conditions are: Tair,out = 9.2195 * ~~~ * Wair,out = 6.586107E-003 * Warning * In calculating the design coil UA for Coil:Cooling:Water HW CHW FOUR PIPE INDUCTION TERMINAL CHW CLG COIL 1 * ~~~ * the apparatus dew-point is below the coil design inlet water temperature; * ~~~ * the coil outlet design conditions will be changed to correct the problem. * ~~~ * The initial design conditions are: Tair,in = 25.9901 * ~~~ * Wair,in = 9.862493E-003 * ~~~ * Twater,in = 7.2200 * ~~~ * Tair,out = 9.2200 * ~~~ * Wair,out = 6.585921E-003 * ~~~ * The revised design conditions are: Tair,out = 9.2195 * ~~~ * Wair,out = 6.586107E-003 * Warning * In calculating the design coil UA for Coil:Cooling:Water HW CHW FOUR PIPE INDUCTION TERMINAL CHW CLG COIL 3 * ~~~ * the apparatus dew-point is below the coil design inlet water temperature; * ~~~ * the coil outlet design conditions will be changed to correct the problem. * ~~~ * The initial design conditions are: Tair,in = 25.9832 * ~~~ * Wair,in = 9.506870E-003 * ~~~ * Twater,in = 7.2200 * ~~~ * Tair,out = 9.2200 * ~~~ * Wair,out = 6.585921E-003 * ~~~ * The revised design conditions are: Tair,out = 9.2195 * ~~~ * Wair,out = 6.586107E-003 * Warning * Controller:MechanicalVentilation = "CONTROLLER MECHANICAL VENTILATION 2", Zone="THERMAL ZONE5-1". * ~~~ * No "PEOPLE" object has been specified in the idf for this zone, but the ventilation rate is > 0 in this Controller:MechanicalVentilation Object. * ~~~ * Check ventilation rate in Controller:MechanicalVentilation object. Simulation will continue. * Warning * Controller:MechanicalVentilation = "CONTROLLER MECHANICAL VENTILATION 2", Zone="THERMAL ZONE5-3". * ~~~ * No "PEOPLE" object has been specified in the idf for this zone, but the ventilation rate is > 0 in this Controller:MechanicalVentilation Object. * ~~~ * Check ventilation rate in Controller:MechanicalVentilation object. Simulation will continue. * Warning * Controller:MechanicalVentilation = "CONTROLLER MECHANICAL VENTILATION 2", Zone="THERMAL ZONE5-5". * ~~~ * No "PEOPLE" object has been specified in the idf for this zone, but the ventilation rate is > 0 in this Controller:MechanicalVentilation Object. * ~~~ * Check ventilation rate in Controller:MechanicalVentilation object. Simulation will continue. * Warning * SizeWaterCoil: Coil="COIL COOLING WATER 1", Cooling Coil has leaving air temperature > entering water temperature. * ~~~ * Tair,out = 12.800 * ~~~ * Twater,in = 82.000 * ~~~ * ....coil leaving air temperature will be reset to: * ~~~ * Tair,out = 82.500 * Warning * SizeWaterCoil: Coil="COIL COOLING WATER 1", Cooling Coil is dry and has air leaving humidity ratio < entering humidity ratio. * ~~~ * Wair,in = 1.549437E-002 * ~~~ * Wair,out = 8.500000E-003 * ~~~ * ....coil leaving humidity ratio will be reset to: * ~~~ * Wair,out = 1.549437E-002 * Warning * The design cooling capacity is zero for Coil:Cooling:Water COIL COOLING WATER 1 * ~~~ * The maximum water flow rate for this coil will be set to zero and the coil will do no cooling. * ~~~ * Check the following coil design inputs for problems: Tair,in = 30.5044 * ~~~ * Wair,in = 1.549437E-002 * ~~~ * Twater,in = 82.0000 * ~~~ * Tair,out = 82.5000 * ~~~ * Wair,out = 1.549437E-002 * Warning * Capacity ratio as a function of temperature curve output is not equal to 1.0 * ~~~ * (+ or - 10%) at reference conditions for ChillerHeaterPerformance:Electric:EIR= CHILLERHEATERMODULE * ~~~ * Curve output at reference conditions = 1.166 * Warning * Energy input ratio as a function of temperature curve output is not equal to 1.0 * ~~~ * (+ or - 10%) at reference conditions for ChillerHeaterPerformance:Electric:EIR= CHILLERHEATERMODULE * ~~~ * Curve output at reference conditions = 0.717 * Warning * Missing temperature setpoint on cooling side for CentralHeatPumpSystem named CENTRAL HP * ~~~ * A temperature setpoint is needed at the outlet node of a CentralHeatPumpSystem, use a SetpointManager * ~~~ * The overall loop setpoint will be assumed for CentralHeatPumpSystem. The simulation continues ... * Warning * Missing temperature setpoint on heating side for CentralHeatPumpSystem named CENTRAL HP * ~~~ * A temperature setpoint is needed at the outlet node of a CentralHeatPumpSystem, use a SetpointManager * ~~~ * The overall loop setpoint will be assumed for CentralHeatPumpSystem. The simulation continues ... * Warning * SizePlantLoop: Calculated Plant Sizing Design Volume Flow Rate=[0.00] is too small. Set to 0.0 * ~~~ * ..occurs for PlantLoop=CONDENSER WATER 2ND LOOP *** Testing Individual Branch Integrity *** All Branches passed integrity testing *** Testing Individual Supply Air Path Integrity *** All Supply Air Paths passed integrity testing *** Testing Individual Return Air Path Integrity *** All Return Air Paths passed integrity testing *** No node connection errors were found. *** Beginning Simulation *** Beginning Simulation
Dear all,
Thank you very much
Have a nice day
Elena
************* Beginning System Sizing Calculations
 *** ************* Beginning Plant Sizing Calculations
 * ** Warning * ** In calculating the design coil UA for Coil:Cooling:Water HW CHW FOUR PIPE INDUCTION TERMINAL CHW CLG COIL 2
 *   ~~~   * **   ~~~   ** the apparatus dew-point is below the coil design inlet water temperature;
 *   ~~~   * **   ~~~   ** the coil outlet design conditions will be changed to correct the problem.
 *   ~~~   * **   ~~~   ** The initial design conditions are: Tair,in = 25.9833
 *   ~~~   * **   ~~~   **                                    Wair,in = 9.554298E-003
 *   ~~~   * **   ~~~   **                                    Twater,in = 7.2200
 *   ~~~   * **   ~~~   **                                    Tair,out = 9.2200
 *   ~~~   * **   ~~~   **                                    Wair,out = 6.585921E-003
 *   ~~~   * **   ~~~   ** The revised design conditions are: Tair,out = 9.2195
 *   ~~~   * **   ~~~   **                                    Wair,out = 6.586107E-003
 *   ~~~   * **   ~~~   ** no apparatus dew-point can be found for the initial entering and leaving conditions;
 *   ~~~   * **   ~~~   ** The initial design conditions are: Tair,in = 25.9845
 *   ~~~   * **   ~~~   **                                    Wair,in = 1.167724E-002
 * ** Warning * ** In calculating the design coil UA for Coil:Cooling:Water HW CHW FOUR PIPE INDUCTION TERMINAL CHW CLG COIL 1
 *   ~~~   * **   ~~~   ** The initial design conditions are: Tair,in = 25.9901
 *   ~~~   * **   ~~~   **                                    Wair,in = 9.862493E-003
 * ** Warning * ** In calculating the design coil UA for Coil:Cooling:Water HW CHW FOUR PIPE INDUCTION TERMINAL CHW CLG COIL 3
 *   ~~~   * **   ~~~   ** The initial design conditions are: Tair,in = 25.9832
 *   ~~~   * **   ~~~   **                                    Wair,in = 9.506870E-003
 * ** Warning * ** Controller:MechanicalVentilation = "CONTROLLER MECHANICAL VENTILATION 2", Zone="THERMAL ZONE5-1".
 *   ~~~   * **   ~~~   ** No "PEOPLE" object has been specified in the idf for this zone, but the ventilation rate is > 0 in this Controller:MechanicalVentilation Object.
 *   ~~~   * **   ~~~   ** Check ventilation rate in Controller:MechanicalVentilation object.  Simulation will continue.
 * ** Warning * ** Controller:MechanicalVentilation = "CONTROLLER MECHANICAL VENTILATION 2", Zone="THERMAL ZONE5-3".
 * ** Warning * ** Controller:MechanicalVentilation = "CONTROLLER MECHANICAL VENTILATION 2", Zone="THERMAL ZONE5-5".
 * ** Warning * ** SizeWaterCoil: Coil="COIL COOLING WATER 1", Cooling Coil has leaving air temperature > entering water temperature.
 *   ~~~   * **   ~~~   **     Tair,out  =  12.800
 *   ~~~   * **   ~~~   **     Twater,in = 82.000
 *   ~~~   * **   ~~~   ** ....coil leaving air temperature will be reset to:
 *   ~~~   * **   ~~~   **     Tair,out = 82.500
 * ** Warning * ** SizeWaterCoil: Coil="COIL COOLING WATER 1", Cooling Coil is dry and has air leaving humidity ratio < entering humidity ratio.
 *   ~~~   * **   ~~~   **     Wair,in =  1.549437E-002
 *   ~~~   * **   ~~~   **     Wair,out = 8.500000E-003
 *   ~~~   * **   ~~~   ** ....coil leaving humidity ratio will be reset to:
 *   ~~~   * **   ~~~   **     Wair,out = 1.549437E-002
 * ** Warning * ** The design cooling capacity is zero for Coil:Cooling:Water COIL COOLING WATER 1
 *   ~~~   * **   ~~~   **   The maximum water flow rate for this coil will be set to zero and the coil will do no cooling.
 *   ~~~   * **   ~~~   **   Check the following coil design inputs for problems: Tair,in = 30.5044
 *   ~~~   * **   ~~~   **                                                        Twater,in = 82.0000
 *   ~~~   * **   ~~~   **                                                        Tair,out = 82.5000
 * ** Warning * ** Capacity ratio as a function of temperature curve output is not equal to 1.0
 *   ~~~   * **   ~~~   ** (+ or - 10%) at reference conditions for ChillerHeaterPerformance:Electric:EIR= CHILLERHEATERMODULE
 *   ~~~   * **   ~~~   ** Curve output at reference conditions = 1.166
 * ** Warning * ** Energy input ratio as a function of temperature curve output is not equal to 1.0
 *   ~~~   * **   ~~~   ** Curve output at reference conditions = 0.717
 * ** Warning * ** Missing temperature setpoint on cooling side for CentralHeatPumpSystem named CENTRAL HP
 *   ~~~   * **   ~~~   **   A temperature setpoint is needed at the outlet node of a CentralHeatPumpSystem, use a SetpointManager
 *   ~~~   * **   ~~~   **   The overall loop setpoint will be assumed for CentralHeatPumpSystem. The simulation continues ...
 * ** Warning * ** Missing temperature setpoint on heating side for CentralHeatPumpSystem named CENTRAL HP
 * ** Warning * ** SizePlantLoop: Calculated Plant Sizing Design Volume Flow Rate=[0.00] is too small. Set to 0.0
 *   ~~~   * **   ~~~   ** ..occurs for PlantLoop=CONDENSER WATER 2ND LOOP
 *** ************* Testing Individual Branch Integrity
 *** ************* All Branches passed integrity testing
 *** ************* Testing Individual Supply Air Path Integrity
 *** ************* All Supply Air Paths passed integrity testing
 *** ************* Testing Individual Return Air Path Integrity
 *** ************* All Return Air Paths passed integrity testing
 *** ************* No node connection errors were found.
 *** ************* Beginning Simulation
 *** ************* Beginning SimulationSimulation
Thanks
Dear all,
Thank you very much
Have a nice day
Elena
** Warning ** In calculating the design coil UA for Coil:Cooling:Water HW CHW FOUR PIPE INDUCTION TERMINAL CHW CLG COIL 2
** Warning ** In calculating the design coil UA for Coil:Cooling:Water HW CHW FOUR PIPE INDUCTION TERMINAL CHW CLG COIL 1
** Warning ** In calculating the design coil UA for Coil:Cooling:Water HW CHW FOUR PIPE INDUCTION TERMINAL CHW CLG COIL 3
** Warning ** Controller:MechanicalVentilation = "CONTROLLER MECHANICAL VENTILATION 2", Zone="THERMAL ZONE5-1".
** Warning ** Controller:MechanicalVentilation = "CONTROLLER MECHANICAL VENTILATION 2", Zone="THERMAL ZONE5-3".
** Warning ** Controller:MechanicalVentilation = "CONTROLLER MECHANICAL VENTILATION 2", Zone="THERMAL ZONE5-5".
** Warning ** SizeWaterCoil: Coil="COIL COOLING WATER 1", Cooling Coil has leaving air temperature > entering water temperature.
** Warning ** SizeWaterCoil: Coil="COIL COOLING WATER 1", Cooling Coil is dry and has air leaving humidity ratio < entering humidity ratio.
** Warning ** The design cooling capacity is zero for Coil:Cooling:Water COIL COOLING WATER 1
** Warning ** Capacity ratio as a function of temperature curve output is not equal to 1.0
** Warning ** Energy input ratio as a function of temperature curve output is not equal to 1.0
** Warning ** Missing temperature setpoint on cooling side for CentralHeatPumpSystem named CENTRAL HP
** Warning ** Missing temperature setpoint on heating side for CentralHeatPumpSystem named CENTRAL HP
** Warning ** SizePlantLoop: Calculated Plant Sizing Design Volume Flow Rate=[0.00] is too small. Set to 0.0
Thanks
