ASHRAE 55 Analytical comfort zone method calculation
Hi there,
I am currently carrying out the calculations required for the LEED thermal comfort credit compliance. However it is not clear to me when this should be evaluated, do I need to use the design winter and design summer times and include them in the calculations assuming 0.5 clo for summer and 1 clo for winter? Have you carried out this calculation before? how did you demonstrate compliance of the standard? I have read that the warmest and the coolest hour of every month should be considered, is this correct?
Could you please confirm these assumptions are correct: 1. I select from the stat the peak cooling and heating hours 2. I run a simulation for those two moments and collect the MRT and RH resilts. 3. I assume the design data for airspeed, 0.5 clo for the summer scenario and 1 clo for the winter scenario and the metabolic rate for the activity or activities.
I input these parameters in the CBE thermal comfort tool for each scenario and confirm whether I met or not the requirements.
Thanks
Hi there,
Could you please confirm these assumptions are correct: 1. correct:
  1. I select from the stat the peak cooling and heating hours 2. hours
  2. I run a simulation for those two moments and collect the MRT and RH resilts. 3. resilts.
Thanks
Hi there,
Thanks
