I am running HVAC detailed simulation using #DesignBuilder and I wanted to compare end uses using two different HVAC system templates. First I used VAV Dual Duct Water-Cooled Chiller and then I replaced the system with Unitary Air-to Air Heat Pump. The total energy consumption in first iteration is two times (~98.9% higher) of the second run which doesn't look like realistic. I wonder if the problem is in the DesignBuilder HVAC templates and I need to modify or customize these templates.
