Hi,
I have two questions: 1. one of my zone is not fully enclosed and there is some errors message but I dont understand the meaning 2. calculated design heat load is zero, we are here not use heating load. How to solve this error?
Program Version,EnergyPlus, Version 9.5.0-de239b2e5f, YMD=2023.04.20 16:19, *** Beginning Zone Sizing Calculations * Warning * CalculateZoneVolume: The Zone="KM WC LT2" is not fully enclosed. To be fully enclosed, each edge of a surface must also be an edge on one other surface. * ~~~ * The zone volume was calculated using the floor area times ceiling height method where the floor and ceiling are the same except for the z-coordinates. * ~~~ * The surface "A8329B" has an edge that is either not an edge on another surface or is an edge on three or more surfaces: * ~~~ * Vertex start { 0.1234, 4.3450, 6.9800} * ~~~ * Vertex end { 0.1234, 4.3450, 3.6000} * ~~~ * The surface "91CD98" has an edge that is either not an edge on another surface or is an edge on three or more surfaces: * ~~~ * Vertex start { 0.1234, 6.2450, 3.6000} * ~~~ * Vertex end { 0.1234, 6.2450, 6.9800} * ~~~ * The surface "97F56C" has an edge that is either not an edge on another surface or is an edge on three or more surfaces: * ~~~ * Vertex start { 0.1234, 6.2450, 6.9800} * ~~~ * Vertex end { 0.1234, 4.3450, 6.9800} * ~~~ * The surface "97F56C" has an edge that is either not an edge on another surface or is an edge on three or more surfaces: * ~~~ * Vertex start { 0.1234, 4.3450, 3.6000} * ~~~ * Vertex end { 0.1234, 6.2450, 3.6000} * Warning * Calculated design heating load for zone=K TIDUR LT1 is zero. * ~~~ * Check Sizing:Zone and ZoneControl:Thermostat inputs. * Warning * Calculated design heating load for zone=R KELUARGA is zero. * ~~~ * Check Sizing:Zone and ZoneControl:Thermostat inputs. * Warning * Calculated design heating load for zone=KAMAR TIDUR LT2 is zero. * ~~~ * Check Sizing:Zone and ZoneControl:Thermostat inputs. * Warning * Calculated design heating load for zone=KAMAR TIDUR UTAMA is zero. * ~~~ * Check Sizing:Zone and ZoneControl:Thermostat inputs. * Warning * Calculated design heating load for zone=VOID is zero. * ~~~ * Check Sizing:Zone and ZoneControl:Thermostat inputs.
thank you very much in advance where I can send the idf files for your checking
regards, Budijanto Chandra
