Water-to-Air central heat pump
Hi,
I am trying to evaluate the replacement of a gas boiler for an office building air-conditioning system, with a heat pump that can meet the air-conditioning needs of the building in both summer and winter.
Could you tell me what component I should use in OpenStudio to simulate a heat pump using air as a cold source, with these characteristics?
https://www.rhoss.it/products/tcaei-thaei-2160%C3%B74350/?print&title=WinPACK%20ECO%20TCAEI-THAEI%202160%C3%B74350
Specifically, I have to evaluate the THAETI 4350 model
I have read some old discussions about there not being such a component available in OS yet, but maybe with the new versions of the programme the problem has been solved
Thank you
Hi,
Thank you
Hi,
Thank you
