I am getting some really confusing set of errors while trying make my mixed use 4-story MF CBECC 2022 model run. I have never seen these before, but also, this is my first model in the new CBECC 2022 this year! (1) First one is regarding the heatpump HVAC system i set up for the dwelling units. There isn't a step which asks to choose the type for air distribution. So I am unable to figure out how to fix the following error "Ducts required for htg & clg systems but assigned distribution system lacks ducts for HVAC system 'L1 Res One-Bed NE HVACSys' (Heat Pump Heating and Cooling System) ('p' run) evaluating run zp rule: Rule 595, 92, 'Rules_ResModelChecks.rule' Line 2287: Check for existing DistribSystem not of a ducted type but assigned to an HVAC system requiring ducts (or vice-versa)" (2) Second one is regarding access and again, I don't know what to do about it "Error: RetrieveCSVValue() error: unable to open CSV file: C:\Users\sborle\Documents\CBECC 2022 Projects\FairviewMF Test\FairviewTerrace_backup1_active - run\FairviewTerrace_backup1_active - zp-hvacSzg.csv evaluating run zp rule: Rule 50, 1, 'Rules_PostSim.rule' Line 43: Retrieve AirSys:SupAirSegRef:CoilHtgRef:CapTotGrossRtdSim from CSE sizing results"
Anyone been here been here before? I have tried deleting the HP system for dwelling unit and recreating it and reapplying it, and also tried saving a new copy in a new folder that is located in the CBECC 2022 Projects on C Drive. How do I solve these errors?
