Clarification on Surface Inside Face Temperature Output Values of Simulation
Hello everyone,
I ran a simulation of my model and set the Surface Inside Face Temperature of a wall named Int_Wall as the output. I obtained two values, which are highlighted in yellow (iz-INT_WALL) and green (INT_WALL).
My question is, what is the difference between these two output values?
Thank you.
Hello everyone,
Thank you.
Hello everyone,
Thank you.
Clarification on Surface Inside Face Temperature Output Values of SimulationValues
Hello everyone,
I ran a simulation of my model and set the Surface Inside Outside Face Temperature of a wall named Int_Wall as the output. I obtained two values, which are highlighted in yellow (iz-INT_WALL) corresponding to the iz-INT_WALL area and green (INT_WALL).corresponding to the INT_WALL area.
My question is, In EnergyPlus InputOutputReferance the Surface Outside Face Temperature is defiened as the temperature of the surface’s outside face which in my case is the INT_WALL area, but what is the difference between these two output values?iz-INT_WALL area ?
Thank you.
Hello everyone,
I ran a simulation of my model and set the Surface Outside Face Temperature of a wall named Int_Wall as the output. I obtained two values, which are highlighted in yellow corresponding to the iz-INT_WALL area and green corresponding to the INT_WALL area.
In EnergyPlus InputOutputReferance the Surface Outside Face Temperature is defiened as the temperature of the surface’s outside face which in my case is the INT_WALL area, but what is the iz-INT_WALL area ?
Thank you.
Clarification on Surface Inside Outside Face Temperature Output Values
Hello everyone,
Thank you.
Clarification on Surface Outside Face Temperature Output Values
Hello everyone,
I ran a simulation of my model and set the Surface Outside Face Temperature of a wall named Int_Wall as the output. I obtained two values, which are highlighted in yellow yellow, corresponding to the iz-INT_WALL area and green corresponding to the INT_WALL area.
Thank you.
Hello everyone,
I ran a simulation of my model and set the Surface Outside Face Temperature of a wall named Int_Wall as the output. I obtained two values, which are highlighted in yellow, corresponding to the iz-INT_WALL area and green corresponding to the INT_WALL area.
Thank you.
Hello everyone,
Thank you.
Hello everyone,
Thank you.
Hello everyone,everyone
Thank you.
Hello everyone
In EnergyPlus InputOutputReferance the Surface Outside Face Temperature is defiened as the temperature of the surface’s outside face which in my case is the INT_WALL area, but area. However, I'm unsure what is the iz-INT_WALL iz-INT_WALL area ?temperature refers to. Could you provide more context or information about this term?
Thank you.
Hello everyone
In EnergyPlus InputOutputReferance the Surface Outside Face Temperature is defiened as the temperature of the surface’s outside face which in my case is the INT_WALL area. However, I'm unsure what the iz-INT_WALL iz-INT_WALL area temperature refers to. Could you provide more context or information about this term?
Thank you.
Hello everyone
I ran a simulation of my model and set the Surface Outside Face Temperature of a wall named Int_Wall as the output. I obtained two values, which are highlighted in yellow, corresponding to the iz-INT_WALL area and green corresponding to the INT_WALL area.area (Figure 1), and both have diffrent value (Figure 2).
In EnergyPlus InputOutputReferance the Surface Outside Face Temperature is defiened as the temperature of the surface’s outside face which in my case is the INT_WALL area. However, I'm unsure what the iz-INT_WALL area temperature refers to. Could you provide more context or information about this term?
Thank you.
Figure 1
Figure 2
Hello everyone
I ran a simulation of my model and set the Surface Outside Face Temperature of a wall named Int_Wall as the output. I obtained two values, which are highlighted in yellow, corresponding to the iz-INT_WALL area and green corresponding to the INT_WALL area (Figure 1), and both have diffrent value (Figure 2).
Thank you.
PS: INT_WALL=PRODUCT_WALL_CONST
Figure 1
Figure 2
Hello everyone
Thank you.
Figure 1
Figure 2
Hello everyone
Thank you.
UPDATES
When I check the results I found that
INT_WALL:Surface Inside Face Temperature = iz-INT_WALL:Surface Outside Face Temperature
INT_WALL:Surface Outside Face Temperature = iz-INT_WALL:Surface Inside Face Temperature
Figure 1
Figure 2
Hello everyone
Thank you.
UPDATES
Figure 1
Figure 2
Figure 3
Hello everyone
Thank you.
UPDATES
Figure 1
Figure 2
Figure 3
image descriptionimage description
