Pier and Beam - Envelope - Error
Received the following error code when attempting to model a manufactured home with a Pier-and-Beam foundation. See model here
2/26/2023 7:00 PM: 6.xml: Error: Expected ExteriorAdjacentTo to be 'ground' or 'basement - conditioned' or 'basement - unconditioned' or 'crawlspace - vented' or 'crawlspace - unvented' or 'crawlspace - conditioned' or 'garage' or 'other housing unit' or 'other heated space' or 'other multifamily buffer space' or 'other non-freezing space' 2/26/2023 7:00 PM: 6.xml: Error: Expected InteriorAdjacentTo to be 'basement - conditioned' or 'basement - unconditioned' or 'crawlspace - vented' or 'crawlspace - unvented' or 'crawlspace - conditioned' or 'garage' 2/26/2023 7:00 PM: 6.xml: Error: Expected ExteriorAdjacentTo to be 'ground' or 'basement - conditioned' or 'basement - unconditioned' or 'crawlspace - vented' or 'crawlspace - unvented' or 'crawlspace - conditioned' or 'garage' or 'other housing unit' or 'other heated space' or 'other multifamily buffer space' or 'other non-freezing space' 2/26/2023 7:00 PM: 6.xml: Error: Expected InteriorAdjacentTo to be 'basement - conditioned' or 'basement - unconditioned' or 'crawlspace - vented' or 'crawlspace - unvented' or 'crawlspace - conditioned' or 'garage' 2/26/2023 7:00 PM: 6.xml: Error: Expected ExteriorAdjacentTo to be 'ground' or 'basement - conditioned' or 'basement - unconditioned' or 'crawlspace - vented' or 'crawlspace - unvented' or 'crawlspace - conditioned' or 'garage' or 'other housing unit' or 'other heated space' or 'other multifamily buffer space' or 'other non-freezing space' 2/26/2023 7:00 PM: 6.xml: Error: Expected InteriorAdjacentTo to be 'basement - conditioned' or 'basement - unconditioned' or 'crawlspace - vented' or 'crawlspace - unvented' or 'crawlspace - conditioned' or 'garage'
2/26/2023 7:00 PM:  6.xml:  Error: Expected InteriorAdjacentTo to be 'basement - conditioned' or 'basement - unconditioned' or 'crawlspace - vented' or 'crawlspace - unvented' or 'crawlspace - conditioned' or 'garage''garage'
Thanks
