Why am I unable to assign labor/material cost information to finished/unfinished attic insulation within the Options Manager?
Hello, I cannot load any cost information for the attic insulation section of BEOpt within the Options Manager. Seems like there wasn't any cost info there to begin with, and when I went into the Options Manager to add some in, this error message popped up:
Message: The following application error has occurred in BEopt v3.0.0.0. Please report this to the BEopt development team and restart the application.
database disk image is malformed database disk image is malformed
Stack Trace: at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt) at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt) at System.Data.SQLite.SQLiteDataReader.NextResult() at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave) at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior) at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery(CommandBehavior behavior) at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery() at NREL.BEopt.BEoptCommon.DBObject.Save(SQLiteCommand cmd, IList1 saveParams, IDictionary2 IDs, IDictionary2 NewIDs, Boolean SupressDeletedRowsCheck) in C:\git\beopt\Source\BEoptSettings\Database\DBObject.cs:line 238 at NREL.BEopt.BEoptCommon.DBLibraryObject.Save(SQLiteCommand cmd, IList1 saveParams, Guid NewID, Boolean SupressDeletedRowsCheck) in C:\git\beopt\Source\BEoptSettings\Database\DBObject.cs:line 336 at NREL.BEopt.BEoptCommon.DBLibraryIsolatedObject.Save(IList`1 saveParams, Guid NewID) in C:\git\beopt\Source\BEoptSettings\Database\DBObject.cs:line 382 at NREL.BEopt.ObjLibCS.EconomicProperty.Save() in C:\git\beopt\Source\BEoptObjLibCS\Measures\EconomicProperty.cs:line 258 at NREL.BEopt.ObjLibCS.Option.Save() in C:\git\beopt\Source\BEoptObjLibCS\Measures\Option.cs:line 678 at NREL.BEopt.UICS.OptionEditor.btnOK_Click(Object sender, EventArgs e) in C:\git\beopt\Source\BEoptUICS\OptionEditor.cs:line 778
Why am I unable to assign labor/material cost information to finished/unfinished attic insulation within the Options Manager?Manager of BEOpt?
Message: Message:
application. database disk image is malformed database disk image is malformed
malformed Stack Trace: at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt) at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt) at System.Data.SQLite.SQLiteDataReader.NextResult() at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave) at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior) at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery(CommandBehavior behavior) at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery() at NREL.BEopt.BEoptCommon.DBObject.Save(SQLiteCommand cmd, IList1 IList`1 saveParams, IDictionary2 IDictionary`2 IDs, IDictionary2 IDictionary`2 NewIDs, Boolean SupressDeletedRowsCheck) in C:\git\beopt\Source\BEoptSettings\Database\DBObject.cs:line 238 at NREL.BEopt.BEoptCommon.DBLibraryObject.Save(SQLiteCommand cmd, IList1 IList`1 saveParams, Guid NewID, Boolean SupressDeletedRowsCheck) in C:\git\beopt\Source\BEoptSettings\Database\DBObject.cs:line 336 at NREL.BEopt.BEoptCommon.DBLibraryIsolatedObject.Save(IList`1 saveParams, Guid NewID) in C:\git\beopt\Source\BEoptSettings\Database\DBObject.cs:line 382 at NREL.BEopt.ObjLibCS.EconomicProperty.Save() in C:\git\beopt\Source\BEoptObjLibCS\Measures\EconomicProperty.cs:line 258 at NREL.BEopt.ObjLibCS.Option.Save() in C:\git\beopt\Source\BEoptObjLibCS\Measures\Option.cs:line 678 at NREL.BEopt.UICS.OptionEditor.btnOK_Click(Object sender, EventArgs e) in C:\git\beopt\Source\BEoptUICS\OptionEditor.cs:line 778778
Thanks
