At the end of OpenStudio 1.7.0 setup, a message appears saying 'Unrecognized sketchup 2015 install location. The OpenStudio SketchUp Plug-in will not be installed'. I've installed SketchUp Make 2015 in the E:\SketchUp\SketchUp 2015 location and the OpenStudio 1.7.0 in the E:\OpenStudio 1.7.0 location. Both are x64 version There's no more available space in C: partition; and it is not recommended to install other programs there rather than the Operative System. I've tried to add an E:\SketchUp\SketchUp 2015 shortcut into the C:\Program Files location and reinstall. But it hasn't worked.
Is there a way to explain OpenStudio setup that SketchUp 2015 is installed in the E:\SketchUp\SketchUp 2015 location?
Thank you.
