I am using Ver 3. I just noticed that the sum of heating component load is much greater than heating delivered load. And same thing for cooling. My "loads not met" is 0 hour. Doesn't it mean the sum of component load should be less than the load delivered? Also, if they are different, does output have the sum of component load anywhere? It's not convenient if I just want to check the load. thanks
