What kind of energy consumptions is included in "water system" in Openstudio and EnergyPlus
Dear all,
I am trying to model a hot water system in Openstudio in which the water flowrate of the proposed case is 23% lower than the baseline.
From the results, the energy consumption under "pumps" was 23% lower in the proposed case which sounded fair. However,the energy consumption under "water system" of the proposed case was 98% lower than the baseline.
I am not sure what are included in the "water system" such that a 23% drop in flowrate resulted in such significant energy saving as all other input parameters in the two models were exactly the same.
I am therefore wondering if that is normal or if I have made a mistake somewhere in the inputs.
Daniel
What kind of energy consumptions is included in "water system" systems" in Openstudio and EnergyPlus
Dear all,
From the results, the energy consumption under "pumps" was 23% lower in the proposed case which sounded fair. However,the energy consumption under "water system" systems" of the proposed case was 98% lower than the baseline.
Daniel
What kind of energy consumptions is are included in "water systems" in Openstudio and EnergyPlus
Dear all,
From the results, the energy consumption under "pumps" was 23% lower in the proposed case which sounded fair. However,the energy consumption under "water systems" of the proposed case was 98% lower than the baseline.
Daniel
What kind of energy consumptions are included in "water systems" in Openstudio and EnergyPlus
Dear all,
From the results, the energy consumption under "pumps" was 23% lower in the proposed case which sounded fair. However,the energy consumption under "water systems" of the proposed case was 98% 50% lower than the baseline.
I am not sure what are included in the "water system" such that a 23% drop in flowrate resulted in such significant a proportionally higher energy saving as all other input parameters in the two models were exactly the same.
Daniel
Dear all,
From the results, the energy consumption under "pumps" was 23% lower in the proposed case which sounded fair. However,the energy consumption under "water systems" of the proposed case was 50% lower than the baseline.
I am not sure what are included in the "water system" such that a 23% drop in flowrate resulted in a proportionally higher energy saving as all other input parameters in the two models were exactly the same.
Daniel
