Hi there,
does anyone have experience in setting the heat transfer algorithm of selected surfaces? According to the IO-Manual, I can set the global behaviour via
HeatBalanceAlgorithm, ConductionTransferFunction, 200; !- Algorithm, Surface Temperature Upper Limit {C}
and can then change this for selected surfaces like this,
SurfaceProperty:HeatTransferAlgorithm:Construction, BO05Override, ConductionFiniteDifference, BO05; !- Name, Algorithm, Construction Name
Seems easy & straightforward. However, I then get a fatal error when trying to run the simulation telling me that "InitialInitHeatBalFiniteDiff: Found Material that is too thin and/or too highly conductive ..." which gives a material name that is not part of the construction addressed.
Any ideas welcome. Best Achim
