Hello,
I'm trying to quantify the electricity saving from (space) heating in a single detached home in Detroit Michigan from installing one single speed heat pump, compared to not having any heat pump. I'm running ResStock on PAT and using buildstock.csv to run 2 scenarios.
The first scenario is when no heat pump is installed, so this is to determine my heating load for the building. For this in buildstock.csv, I set:
- HVAC System Is Heat Pump: No
- HVAC System Heat Pump: None
- HVAC System Heating Electricity: Electric Baseboard
The second scenario is when heat pump (ASHP, SEER 13, 8.0 HSPF) is adopted in the same building, everything else stayed the same. For this, I set:
- HVAC System Is Heat Pump: Yes
- HVAC System Heat Pump: ASHP, SEER 13, 8.0 HSPF
- HVAC System Heating Electricity: None
Comparing the electricity_heating_kwh from enduse_timeseries.csv in these two scenarios, I want to see how much electricity_heating_kwh is reduced from using heat pump.
However, for the first scenario (no heat pump), electricity_heating_kwh = 15,698 kWh, but the second scenario (with heat pump), electricity_heating_kwh = 0, so this does not capture any electricity consumed by the heat pump at all?
Is there something that I did wrong here? Thanks in advance for your help
