Hello all,
I have created the following plant loop as an air-to-water heat pump serves for SH purpose, the end heat emitters are convective radiators. The model can run successfully, however, I want to know which of the variables or meters indicate the elecrtrictiy used by the AWHP and the heat output by AWHP? Is the Other Subcategory in water system the elecrtrictiy used by the AWHP?
I am now picking WaterSystems:Electricity for the former one and Heating:EnergyTransfer for the latter one. Or there is any table for the values? Thank you for any answer.
