Hello everyone,
I would like to use the EP-Launch basement utility but it crashes immediatly when I run it. I'm on E+ 8.9 (compatible with the DesignBuilder version I am using), and I think the IDF file contains all objects needed (including Site:GroundDomain:Basement), but the audit file indicates that no object is found :
Basement Audit File
Program Version,GroundTempCalc - Basement, Version .5
* Severe * IP: IDF line~4 Did not find "Version" in list of Objects
* Severe * IP: IDF line~6 Did not find "RunPeriod" in list of Objects
* Severe * IP: IDF line~18 Did not find "RunPeriodControl:DaylightSavingTime" in list of Objects
* Severe * IP: IDF line~22 Did not find "Site:Location" in list of Objects
Do you know how to fix this problem ? Thanks
