The attached image suggests the 'AirLoop Component Load Summary' is indicating the Peak Load data. But when the zone level loads (fenestration solar, people, lights, etc.) are summed up, the difference suggests it might be the block load that is being indicated in the EnergyPlus report. Is this the case or is there any other section of the report which indicates the block loads of the air systems? Thank you in advance for your help.
