I'm attempting to use the NZEHVAC Whole Building Measure to model a heat pump in a DOE Prototype Building. However it fails and gives this error message.
[15:37:51.450948 ERROR] Unable to perform sizing run for hvac system DOAS with fan coil chiller with central air source heat pump for this model. Check the openstudio-standards.log in this measure for more details
Where would I look for this log for the measure?
